Do (L^2)op and (Lz)op Commute?
  • Thread starter Thread starter metgt4
    Commutation
The discussion centers on the commutation of angular momentum operators in quantum mechanics, specifically (L^2)op and (Lz)op. It is established that while (Lx)op and (Ly)op do not commute, they satisfy the relation (Lx)op(Ly)op - (Ly)op(Lx)op = i(hbar)(Lz)op. The user Andrew incorrectly attempted to express Lz in terms of Lx and Ly without including the necessary factor of 1/(i hbar), leading to confusion regarding the commutation of (L^2)op and (Lz)op. The correct approach involves maintaining the imaginary unit i to ensure proper cancellation in calculations.
  • Understanding of quantum mechanics and angular momentum operators
  • Familiarity with the commutation relations of operators
  • Knowledge of complex numbers and the imaginary unit i
  • Basic proficiency in mathematical manipulation of operator equations
  • Review the properties of angular momentum operators in quantum mechanics
  • Study the implications of the commutation relations on quantum states
  • Learn about the significance of the imaginary unit i in quantum mechanics
  • Explore the concept of unit systems in quantum mechanics, particularly setting hbar = 1
Students and professionals in quantum mechanics, particularly those studying angular momentum and operator algebra, will benefit from this discussion.
metgt4
It has been shown that the operators (Lx)op and (Ly)op do not commute but satisfy the following equation:
(a) Use this relation and the two similar equations obtained by cycling the coordinate labels to show that (L2)op(Lz)op = (Lz)op(L2)op, that is, these two operators commute. [Hint: You do not need to introduce the differential formulas for the operators. Use the fact that (AB)C = A(BC) where A, B, and C are operators]
The question continues, but this is the part I am having trouble with.
Relevant equations are included in the question
My attempted solution is attached (Scan0004.jpg). I work it out, but I'm going wrong somewhere as I'm finding that they do not commute as they should.
Thank you in advance for any help!
Andrew
This is a rather convoluted way to do this, so I'm not going to try to pick apart all of it. But I can tell you that you have a significant error in the very first three lines. You have attempted to set
[tex]L_z = L_x L_y - L_y L_x[/tex]
when the correct expression is
[tex]L_z = \frac{1}{i \hbar} (L_x L_y - L_y L_x)[/tex]
Now, if you like, you can set [itex]\hbar = 1[/itex], as this amounts to just choosing a special system of units. However, you cannot set [itex]i = 1[/itex]. The imaginary unit i is crucial to getting the cancellation you need.
13K
