Work done by spring with weight to the spring
The work done by a spring is expressed as Ws = -0.5kx², where k is the spring constant and x is the displacement. When considering a spring with weight, the total work done is modified to include gravitational effects, resulting in Ws = -0.5kx² - m(spring)g, where m(spring) is the mass of the spring and g is the acceleration due to gravity. The weight of the spring is significant in vertical configurations, while it can be disregarded in horizontal setups due to the nature of conservative forces.
  • Understanding of Hooke's Law and spring constants
  • Basic knowledge of gravitational forces and potential energy
  • Familiarity with conservative forces in physics
  • Concept of work-energy principle in mechanics
  • Research the implications of mass on spring dynamics in vertical configurations
  • Explore the work-energy theorem and its applications in conservative systems
  • Learn about the differences in spring behavior in horizontal vs. vertical orientations
  • Investigate the effects of damping and external forces on spring systems
Physics students, mechanical engineers, and anyone studying dynamics and energy in spring systems.
NoBodyKnows
Hey, I just have a quick question. I understand that the work done by a spring is considered as the following; Ws=-.5kx^2. What if the spring has weight to it? Would the work done by the spring be Ws=-(.5kx^2)-m(spring)g? Does the weight get added or is it not even considered in that equation?
Cheers!
*i'm saying the weight is the spring, I understand where the weight the spring is holding is associated but what about the mass of the spring if there is one
In the absence of more data, about all you can say about the work done by a spring that is not massless is, since both spring and gravity forces are conservative,
[tex]W_s + W_g = - (\Delta U_s + \Delta U_g)[/tex]. If the spring was horizontal, its mass wouldn't matter, but the case would be different if the spring was vertically mounted.
  • · Replies 17 ·
  • · Replies 58 ·
  • · Replies 56 ·
