Find pH at Endpoint: Formic Acid Titration with NaOH Solution - 8.32 Answer
  • Thread starter Thread starter coookiemonste
    Titration
The pH at the endpoint of a titration involving 10 mL of formic acid (HCOOH) and 31.23 mL of 0.1034 M NaOH is calculated to be 8.32. The initial concentration of formic acid is determined to be 0.3229 M. The pKa of formic acid is 3.75, and the relationship between the acid and its conjugate base is established using the equation pH = pKa + log[A-]/[HA]. At the equivalence point, the solution consists of sodium formate, which acts as a weak base, necessitating the calculation of [OH-] to derive the final pH.
  • Understanding of acid-base titration concepts
  • Familiarity with the Henderson-Hasselbalch equation
  • Knowledge of weak acid and its conjugate base properties
  • Basic skills in stoichiometry and molarity calculations
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about the properties of weak bases and their pH calculations
  • Explore the concept of equivalence point in titrations
  • Investigate the relationship between Ka, Kb, and Kw in acid-base chemistry
Chemistry students, educators, and laboratory technicians involved in acid-base titration experiments and pH calculations.
coookiemonste
10 mL of a solution of formic acid HCOOH required 31.23 mL of .1034 M NaOH to titrate it. Find the pH at the endpoint. Answer is 8.32.
pH=pKa + log[A-]/[HA]
initial concentration of HCOOH is .3229 M from fact .1034 M(.03123L)=.003229 mol NaOH, .003229mol HCOOH/.01L =concentration of HCOOH.
pka= 3.75
A different viewpoint can be more helpful, starting with the salt as a base (opposite of "acid").
Ka*Kb=Kw, reaction being H2O + NaA <--------> Na+ + OH- + HA
but you only care about H2O + A- <------> OH- + HA.
Kw/Kb = ([OH-](Facid + [OH-])/(Fsalt - [OH-]) = [OH-][HA]/[A-]
(please make your own adjustments for my bad typesetting, or lack of good typesetting).
From the "K" line, you really want to focus on: Kw/Kb = ([OH-](Facid + [OH-])/(Fsalt - [OH-])
Facid means the formal concentration of the weak acid, which is extremely small at the endpoint.
Fsalt means the formal concentration of the sodium formate, as if the titration solution were prepared only from this salt alone without use of acid or base.
At the equivalence point (which is what you can calculate, end point is when you have detected titration should stop) you have a solution of formate, so you just calculate pH of salt. That means - as symbolipoint suggested - treating solution as solution of a weak base HCOO- and calculating [OH-], then converting it to pH.
Much more here:
acid base titration equivalence point calculation
