Atomic Radii of Fe and Ni: Which to Trust?
The discussion revolves around the varying atomic radii values for iron (Fe) and nickel (Ni) encountered in different sources, particularly in the context of a homework problem involving plane density calculations for these metals. Participants explore the implications of these discrepancies and the definitions of atomic radius.
  • Homework-related
  • One participant notes differing atomic radii values for Fe from various sources, including Wikipedia and Chemicool, and questions which value to trust.
  • Another participant asks whether the atomic radii in question refer to zero valent iron and nickel or their ionic forms, highlighting that ionic radii depend on coordination number and oxidation state.
  • A suggestion is made to check the IUPAC site for atomic radius data, although the reliability of the source is questioned.
  • It is proposed that the atomic radius values might pertain to the gas phase, and that the atomic radius can change when a metal atom is part of a lattice structure.
  • One participant expresses confusion about the definition of atomic radius, suggesting that different interpretations could lead to the observed discrepancies in values.
  • A participant shares their calculations for plane density using specific atomic radii for Fe and Ni, but expresses uncertainty about the correctness of the values used.
  • Another participant recommends consulting a specific textbook for potentially reliable information on atomic radii.
Participants do not reach a consensus on which atomic radius values to trust, and multiple competing views regarding the definition and context of atomic radius remain unresolved.
There are limitations regarding the definitions of atomic radius, the context in which these values are measured (gas phase vs. solid state), and the potential influence of coordination number and oxidation state on ionic radii.
Dell
for the calculations in one of my homework questions, i need to use the atomic radii of Fe and Ni, the problem is that every site i come across gives me different values
Fe
wikipedia 126pm
physlink 1.72A
chemicool 140pm
how do i know which one to "trust" ?
Is that zero valent iron and nickel or one of their ions?
The ionic radii for ions are a function of their coordination number and oxidation #.
I think I have seen such data on IUPAC site, even if it is not correct, source sounds as reliably as possible.
No idea what is the definition of atomic radius, could be differences can be attributed to different understanding of what the atomic radius is.
It is likely the atomic radius in gas phase. Putting a metal atom in a metal lattice can change the radius as well.
That's more or less what I am aiming at - depending on the way you want it, you will get different numbers. Even in the gas phase it is not obvious to me what 'size' means, as atoms don't end abruptly :wink:
im really confused,, the question goes like this
find the plane density for the plane [1 1 1] of the following:
iron (BCC)
nickel (FCC)
for [111] i know that
BCC- R=sqrt(3)/4*a
FCC- R=sqrt(2)/4*a
PD=n/A
BCC[111]- PD=sqrt(3)/(16*R^2)
FCC[111]- PD=sqrt(3)/(6*R^2)now all i need to do is find the CORRECT radius to use, i used
FE 126pm
Ni 124 pm
and got
PD(Fe)= 6.818*10^-6 [atoms/pm^2]
PD(Ni)= 1.877*10^-5 [atoms/pm^2]
but i don't know if that's right
  • · Replies 24 ·
  • · Replies 38 ·
