How to make a series circuit using ?
The discussion revolves around constructing a series circuit using a battery, a bulb, and a switch. Participants are exploring the arrangement and connection of these components within the context of series and parallel circuits.
  • Conceptual clarification, Problem interpretation
  • Participants are attempting to visualize the circuit layout and questioning the differences between series and parallel circuits. There are discussions about the correct arrangement of components and the implications of their connections.
The discussion is active with participants sharing their interpretations of circuit layouts. Some guidance has been provided regarding the definitions of series and parallel circuits, and there is an ongoing exploration of how to properly represent these circuits.
Participants have mentioned difficulties in uploading visual representations of their circuit designs, which may affect their ability to communicate their ideas effectively.
andyboy179
how to make a series circuit using a battery, a bulb and a switch?
would it be a battery sign on the top, then on the left hand side a bulb then on the bottom a switch?
Thread moved from Other Sciences to Intro Physics.
Welcome to the PF, Andy. Can you tell us what is different between a "series" circuit and a "parallel" circuit? How are the components connected in those two types of circuits?
hi, a series circuit in in a square and a parallel circuit is there it all goes down if u get what I am on about? like you would have the battery at the top and the bulb would be under it. all i need is a circuit with a bulb, a battery and a switch, i drew what i thought might have been right but it was too big to upload
Correct. In a parallel circuit, all the components are placed side-by-side, and their top terminals are all connected together, and their bottom terminals are all connected together. (Although it doesn't matter if they are drawn all vertical or all horizontal, as long as they are connected in parallel.)
In a series circuit, the components are connected nose-to-tail, in a circle or square as you say.
thankyou very much o:)
