Zombie PDE Model: Creating a Theoretical Outbreak
  • Thread starter Thread starter Lionheart814
    Model Pde
The discussion revolves around modeling a theoretical zombie outbreak using Partial Differential Equations (PDEs). The original poster defines a population density function for humans and zombies, considering a circular boundary and the effects of radius on population density.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to establish boundary and initial conditions for the PDE but struggles with determining the rate of change of human population density over time. They consider modeling the problem in polar coordinates and question the applicability of the heat equation.
Some participants provide mathematical insights, such as the Laplacian in polar coordinates, while others engage in off-topic comments. The original poster expresses frustration with the lack of helpful responses and seeks constructive guidance.
There are indications of trolling and off-topic remarks within the discussion, which may hinder the focus on the mathematical problem at hand. The original poster's inquiry is framed within the constraints of their assignment and the specific modeling requirements.
Lionheart814
Hey guys,
I'm currently taking a Partial Differential Equations class, and for one assignment we have to come up with a model for a theoretical zombie outbreak. Well anyways, this is what I have gathered thus far:
- I am defining my u(r,z,t) to be the population density of humans, where r=radius, z=zombies, and t=time.
- There will be a continuous flow in and out of humans out of the boundary.
- I am letting my boundary be a circular region, suppose a 35 meter radius.
- The population density of both zombies and humans is dependent on the radius, r, of the region. For example if you have 100 zombies in a particular radius with 50 humans, if you increase the radius then the population density decreases.
I think I may have my boundary condition where Du/Dr(35,z,t)= flux, since the normal derivative will always be the radius.My Initial condition is u(r,z,0)= u0
Now, the PDE is where I am having trouble, I can't figure out what Du/Dt is (the rate of change of human population density with respect to time).I tried modeling it similar to the heat equation, but that doesn't work since I only have one spatial dimension in r, and no theta. As r changes as does the total density (zombies and humans) and therefore human density.
If no one knows how to do it this way, then how about in terms of polar coordinates with theta?
The Laplacian in polar coordinates is
[tex]\nabla^2 f= \frac{1}{r}\frac{\partial}{\partial r}\left(r\frac{\partial f}{\partial r}\right)+ \frac{1}{r^2}\frac{\partial^2 f}{\partial \theta^2}[/tex]
If f is circularly symmetric (independent of [itex]\theta[/itex]), this is just
[tex]\nabla^2 f= \frac{1}{r}\frac{\partial}{\partial r}\left(r\frac{\partial f}{\partial r}\right)[/tex]
-_____- let's go grab some more beer
i hope this formula helps
then use this
this is best formula
:shy:
I'm sorry, but that is of little help THawk and Red. I do not know who this Laval person is, and I would appreciate that you cease your trolling at once, or face certain consequences by a moderator.
Thank you.
mr lionheart
we're gona send this link to dr. lav
gl~
and i hope this formula helps~
So you are all in the same class? I'm glad I'm not teaching that class. (And so should you be.)
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 27 ·
