| Thread Closed |
l'hospitals rule |
Share Thread |
| Nov20-09, 08:36 PM | #1 |
l'hospitals rule
evaluate the limit [tex] (lim.t\rightarrow0) \frac{e^6^t-1}{t} [/tex] 2. Relevant equations l'hospital's rule i guess 3. The attempt at a solution With the usual approach of this rule, you are suppose to take a derivative and evaluate the derivative at that original limit. The problem is that every time I take a derivative and apply the limit I keep getting an indeterminate form. I don't know how to solve this. Can someone point me in the right direction? Thanks |
| Nov20-09, 08:39 PM | #2 |
Once you use l'Hôpital's rule once, it's not in an indeterminate form and you can find the limit. Try showing your work.
| Nov20-09, 08:51 PM | #3 |
ok so
[tex] \frac {d}{dx} (\frac {e^6^t-1}{t}) = \frac{t(6e^6^t)-(e^6^t-1)}{t^2} = \frac {6te^6^t-e^6^t+1}{t^2}[/tex] apply the limit [tex] \frac{0-1+1}{0}= \frac {0}{0} [/tex] |
| Nov20-09, 08:57 PM | #4 |
l'hospitals rule
When using l'Hôpital's rule, you take the derivative of the top and bottom separately, do not use the difference
[tex]\lim_{x\rightarrow 0}\frac{f(x)}{g(x)} = \lim_{x\rightarrow 0}\frac{f'(x)}{g'(x)}[/tex] |
| Nov20-09, 09:00 PM | #5 |
oh so NO quotient rule? oh ok. let me redo it then hold on.
| Nov20-09, 09:01 PM | #6 |
well just looking at it the answer is 6. wow thanks for that. I thought you had to use the quotient rule.
many thanks |
| Thread Closed |
Similar discussions for: l'hospitals rule
| L'Hospitals Rule | Calculus & Beyond Homework | 4 | ||
| l'Hospitals Rule | Calculus & Beyond Homework | 1 | ||
| Can I use L'Hospitals rule here? (seem like i use it too often...) | Calculus & Beyond Homework | 7 | ||
| L'Hospitals Rule | Introductory Physics Homework | 1 | ||
