Finding Relative Extrema of x^2y^2 with Constraint 4x^2+y^2=8
  • Thread starter Thread starter iceman
    Extrema Relative
The problem involves finding relative extrema of the function x^2y^2 subject to the constraint 4x^2 + y^2 = 8. Participants are exploring two methods: eliminating a variable and using Lagrange multipliers.
  • Mixed
  • Participants discuss rewriting the object function using the constraint and setting derivatives to zero. There is also exploration of the gradient method for Lagrange multipliers, with some participants questioning the correctness of derivatives and equations derived from them.
Some participants have successfully found relative extrema using one method but express difficulty with the Lagrange multipliers approach. There is an ongoing examination of the equations derived from the gradient, with corrections and alternative interpretations being suggested.
Participants are working under the constraints of the problem and are addressing potential mistakes in their calculations, particularly regarding derivatives and the setup of equations.
iceman
Please help me?? I'm having great difficulty solving this question.
Find all relative extrema of x^2y^2 subject to the constraint 4x^2+y^2=8. Do this in two ways:
a)Use the constraint to eliminate a variable
b)Use the method of Lagrange multipliers.
Your help will be greatly appreciated.
From the constraint y^2= 8- 4x^2 so we can rewrite the object function as f(x,y)= x^2y^2= x^2(8- 4x^2)= 8x^2- 4x^4= F(x).
Now find F' and set it equal to 0.
To use Lagrange Multipliers, rewrite the object function
as F(x,y)= x^2y^2+ lambda(4x^2+ y^2- 8) and take the gradient:
grad F= (2xy^2+ 4 lambda x)i+ (2x^2y+ 2 lamda y)j
Set that equal to 0i+ 0j and with 4x^2+ y^= 8 you have three equation with which to determine x,y, and lambda.
Hi HallsofIvy, since you last posted your reply to my problem I've been working on finding the solution.
I managed to find all the relative extrema for a) by eliminating a variable.
But I'm having real trouble finding all the relative extrema for b) using the method of lagrange multipliers?
From your advice, I set the grad F= (2xy^2+ 4 lambda x)i+ (2x^2y+ 2 lamda y)j equal to zero and got
2xy^2+ 4 lambda x=0
2x^2y+ 2 lambda y=0
4x^2+ y^2= 8
solving for x,y and lambda:
y^2=8-4x^2 so y=sqrt(8-4x^2)
4x^2=8-y^2 so x^2=(8-y^2)/4 and x=sqrt[(8-y^2)/4]
so substituting y^2, x^2, x, and y into 2x^2y+ lambda x=0 I get;
2x(8-4x^2) + 4 lambda x =0
This is where it all gets a little bit weird!
Can anyone show me how they would approach this and help solve my dilemma?
Your help is much appreciated.
Regards
I was about to chastise you for doing the derivative wrong when I realized you had copied MY mistake. The derivative of 4x^2 is, of course, 8x not 4x so 2xy^2+ 4 lambda x=0 should be 2xy^2+ 8lambda x= 0.
the three equations are
2xy^2+ 8 lambda x=0
2x^2y+ 2 lambda y=0
4x^2+ y^2= 8
The way I would solve them is to rewrite the first equation as 2x(y^2+ 2lambda)= 0. Either x= 0 or y^2+ 2lambda= 0.
If x= 0 then y^2= 8 so y= +/- 2sqrt(2) (from the last equation).
The middle equation can be rewritten (4x^2+ 2lambda)y= 0. Either y= 0 or 4x^2+ 2lambda= 0.
If y= 0 then 4x^2= 8 so x= +/- sqrt(2) (from the last equation).
If neither x nor y is zero then we have y^2+ 2lambda= 0 so
lambda= -(1/2)y^2 and 4x^2+ 2lambda= 0 so lambda= -2 x^2. Those together give -2x^2= -(1/2)y^ or y^2= 8x^2.
Putting that into 4x^2+ y^2= 8, 4x^2+ 8x^2= 8 or 12x^2= 8.
x^2= 8/12= 2/3 so x= +/- sqrt(2/3) and 4(2/3)+ y^2= 8 so
y^2= 8- 8/3= 16/3 and y= +/- 4sqrt(1/3).
The "critical points" are (sqrt(2), 0), (sqrt(2), 0),
(0,2 sqrt(2)), (0, -2 sqrt(2)), (sqrt(2/3), 4 sqrt(1/3)),
(-sqrt(2/3), 4 sqrt(1/3)), (sqrt(2/3), -4 sqrt(1/3)), and
(-sqrt(2/3), -4 sqrt(1/3)).
BLAST IT! I accidently hit the "post" button while I was in the middle of correting my mistake.
2xy^2+ 8 lambda x=0
2x^2y+ 2 lambda y=0
4x^2+ y^2= 8
2x(y^2+ 4lambda)= 0. Either x= 0 or y^2+ 4lambda= 0.
The middle equation can be rewritten 2(x^2+ lambda)y= 0. Either y= 0 or x^2+ lambda= 0.
If neither x nor y is zero then we have y^2+ 4lambda= 0 so
lambda= -(1/4)y^2 and x^2+ lambda= 0 so lambda= -x^2. Those together give -x^2= -(1/4)y^ or y^2= 4x^2.
Putting that into 4x^2+ y^2= 8, 4x^2+ 4x^2= 8 or 8x^2= 8 and x= +/1.
If x= +/- 1, then 4+ y^2= 8 or y^2= 4 so y= +/- 2.
(0,2 sqrt(2)), (0, -2 sqrt(2)), (1, 2), (-1, 2), (1, -2), and (-1, -2)
, exactly the same result you get by eliminating a variable.
