Newton's Law of Cooling constant k
The discussion revolves around Newton's Law of Cooling, specifically focusing on the constant k, its representation, units, and its applicability in scenarios involving heating of cold objects in warmer environments.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant inquires about the meaning and units of the constant k in Newton's Law of Cooling.
  • Another participant suggests that k corresponds to the convective coefficient h, which has units of W/(m²·K), and provides an equation related to the law.
  • This second participant warns against calculating h theoretically, mentioning the complexity of fluid dynamics and the potential dangers involved.
  • A third participant directs others to external resources for further information on k and its implications.
  • A fourth post presents a mathematical expression related to the law, indicating a differential equation format.
The discussion does not appear to reach a consensus on the definition of k or its implications, as participants express varying levels of understanding and provide different types of information.
There are limitations regarding the assumptions about the conditions under which Newton's Law of Cooling applies, particularly in relation to the heating of cold objects and the complexity of calculating the convective coefficient.
This discussion may be useful for individuals interested in thermodynamics, heat transfer, or those seeking clarification on Newton's Law of Cooling and its applications.
maccaman
In Newton's Law of Cooling, we have the constant k, i was just wondering (most people will prolly laugh at me) what the constant k represents, and what units this constant would have.
Also, can the law describe a cold object being heated up in a warmer environment.
Any help would be greatly appreciated, thanks.
You should typewrite your equation us to be sure. I guess you want to say:
q=h*(T-Ts) (Newton Law of cooling);
where h (k yours) is the convective coefficient in W/(m^2)K
Well, I wish you will never need to calculate h theoretically. It is used when it exists a heat transferring due to fluids movement or fluid to solid boundary movement. It could be calculated in two ways:
i) solving Navier Stokes equation for the fluid motion. (it would be dangerous for your health).
ii) using heavies correlations involving the Fluid Mechanics Numbers (Reynolds, Prandtl, Nusselt, etc).
dy/dx = k(y - C)
  • · Replies 62 ·
  • · Replies 20 ·
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 46 ·
