Finding Two Points on a Graph with Midpoint (0,0)
  • Thread starter Thread starter Denyven
    Graph Points
The problem involves finding two points on the graph of the quadratic function y=4x²+7x-1, given that the midpoint of the line segment connecting these points is at (0,0).
  • Exploratory, Assumption checking
  • The original poster attempts to derive relationships between the coordinates of the points based on the midpoint formula, leading to equations for x₁, x₂, y₁, and y₂. Some participants question the feasibility of finding the points without additional information about at least one of them. Others explore the implications of the midpoint conditions and suggest converting equations between x and y coordinates.
The discussion is ongoing, with participants exploring various interpretations of the midpoint conditions and the relationships between the coordinates. Some guidance has been offered regarding the equations derived from the midpoint formula, but no consensus has been reached on the next steps or the specific values of the points.
There is a noted lack of information regarding the specific location of at least one of the points, which some participants highlight as a constraint in solving the problem.
Denyven
Two points are located on the graph [tex]y=4x^{2}+7x-1[/tex]. A line drawn between these two points have a mid-point at (0,0). Find these two points.
The midpoint formula [tex](x_{m},y_{m})=(\frac{x_{1}+x_{2}}{2},\frac{y_{1}+y_{2}}{2})[/tex]
I have worked out the distance from a point on the graph to the origin as a function of x [tex]d=\sqrt{16x^{4}+56x^{3}+42x^{2}-14x+1}[/tex], by plugging in the parabolic equation into the [tex]d=\sqrt{x^{2}+y^{2}}[/tex]. I have also figured out these set of rules for [tex]x_{1}, x_{2}, y_{1}[/tex] and [tex]y_{2}[/tex]:
[tex]x_{1}+x_{2}=0[/tex] and [tex]y_{1}+y_{2}=0[/tex]
Thus [tex]x_{1}= -x_{2}[/tex] and [tex]y_{1}= -y_{2}[/tex]
All of the above were derived from the midpoint formula, since the mid-point is (0,0), both the x's and the y's have to cancel out each other.
Thanks in Advance!
This is interesting, i don't think its possible to find the where these points are located without any information about where at least one of them is.
but i may just not be looking close enough for a solution.
Hi Denyven! :wink:
ok, so y1 + y2 = 0.
Now convert that equation into x1 and x2.
What do you get? :smile:
Tiny Tim,
What do you mean convert y1+y2 into x1+x2?
Like this [tex]x_{1}+x_{2}=y_{1}+y_{2}[/tex]
Or plug the equation of a parabola into the y1+y2?
Which would yield [tex]y=8x^{2}+14x-2[/tex], who's zeros are [tex]x=\frac{1}{8}(-7-\sqrt{65})[/tex] and [tex]x=\frac{1}{8}(\sqrt{65}-7)[/tex].
Are these the x values of either points?
Denyven said:
Tiny Tim,
No, I said x1 and x2.
… Or plug the equation of a parabola into the y1+y2?
What on Earth are you doing?
What happened to x1 and x2? :confused:
Put them back!
oh ha,
so do you mean x1=y1+y2-x2 and x2=y1+y2-x1?
No, I mean y1 = 4x12 + 7x1 - 1
and y2 = 4x22 + 7x2 - 1
  • · Replies 16 ·
  • · Replies 19 ·
