Capacitance of eccentrical cylinders
  • Context: Graduate
  • Thread starter Thread starter Gagson
    Capacitance Cylinders
The discussion revolves around the capacitance of two eccentrically located cylinders, focusing on the mathematical modeling and potential calculations involved in determining their capacitance. Participants explore various methods, including the method of images and complex variable approaches, while addressing the challenges posed by the geometry of the system.
  • One participant describes their approach using the method of images and provides a formula for potential based on distances from the cylinders.
  • Another participant questions the use of the ratio R2/R1 = k and suggests that the distance between the plates is crucial for understanding the equipotential surfaces.
  • A different participant provides a formula for capacitance per length, referencing a specific textbook and noting the complexity of the problem.
  • There is a clarification about notation, specifically the meaning of the double asterisk in mathematical expressions.
  • A participant shares their success in arriving at the same capacitance formula using Mathematica, while explaining their interest in the constant k for determining equipotential lines.
  • Further mathematical relationships are discussed, including the differences in centers of the cylinders and the ratios of their radii.
Participants express various approaches and calculations regarding the capacitance problem, with no clear consensus on a single method or solution. Multiple competing views and techniques are presented, indicating an ongoing exploration of the topic.
Some participants reference specific mathematical techniques and formulas, but there are unresolved assumptions regarding the values of certain variables, such as d, and the implications of the geometry on the calculations.
Gagson
Hi, I have a problem about the capacitance of two cylinders eccentrically located one inside the other - with radii a and b resp., their centers have a distance c apart. I've tried that with the method of images, considering the eqipotential "cylinders" of a system of two infinite parallel lines of charges at distance 2d apart.
The potential at any point P on the plane perpendicular to the lines is given by V = (q/(2Pi*Eps))ln(R2/R1)
where q is the charge density
R1 and R2 are the distances from line 1 and line 2 respectively, i.e. r1^2 = (x-d)^2+y^2 and r2^2 = (x+d)^2+y^2
To get eqipotential lines of the system, we equate R2/R1 to a constant k and then we get a family of circles of the plane with center at h = d(k^2+1)/(k^2-1) and radius R = [2dk/(k^2-1)] ^2
Everything seems fine. If i can figure out the two values of K corresponding to the two equipotential "circles", I will know the p.d, as well as the capacitance.
However, I have problem to solve them out without knowing the value of d.
Can someone help? :smile:
Thanks very much.
G.G
Reference:
Carl T.A. Johnk, Engineering Electromagnetic Fields and Waves 2nd Ed., pp. 222-225
I'm sorry that no one seems to want to help you with this one. I will give it a shot.
I do not understand what you are trying to do with R2/R1 = k. You already have the equipotential surfaces given by:
V = (λ/2π&epslion;0) ln(ρ21).
One of the tricks is to realize that 2d = ρ1 + ρ2.
The other basic trick is to realize that the distance between the plates is b - (a + c), and that this distance represents the distance between the two different equipotential surfaces of interest.
Finally, a word of caution: remember that, in general, neither image charge will lie at the center of neither conductor.
I hope I didn't just tell you stuff that you already know.
The answer you want for the capacitance per length is
C= 2pi*epsilon*{1/[inverse cosh(-1*(c**2-a**2-b**2)/2ab)]}
the units are such that the Coloumb potential is (1/4pi*epsilon)Q/R
This is worked out in the book Static and Dynamic Electricity by Symthe, Chapter 4. --once the scourge of most physics graduate students, among others, we prayed that such a problem would not turn up in our qualifiers or orals. You are posing a difficult problem, which is solved via complex variable approaches also used in fluid dynamics, stream functions and all that. Symthe wrote his book in the late 1930s at which time the emphasis on mathematical detail and prowess was considerable different than it is now.
Regards,
reilly Atkinson
reilly,
That looks so familiar. What does the ** (double asterisk) mean?
Turin -- a**2 means a*a, harks back to FORTRAN. in which ** means exponentiation Regards, Reilly
Thanks reily and turin,
It turned out that I arrived at the same answer with the help of Mathematica without bothering the complex analysis technique.
turin, why i care about the constant k? Coz it gives me the family of circles that represent the equipotential lines. So each of the two conducting cylinders should be one in the family with different k's with center at (h,0) and radius R.
[tex]h = d \frac{k^2+1}{k^2-1} (1)[/tex]
[tex]R = \frac{2dk}{k^2-1} (2)[/tex]
Let say the center of the inner one is at (h1, 0), and the other is at (h2,0).
Then [tex]h1 = d \frac{k1^2+1}{k1^2-1})[/tex] and [tex]h2 = d \frac{k2^2+1}{k2^2-1})[/tex] by (1).
Their difference c turns out to be simple becoz of (2).
[tex]c = \frac{r2}{k2} - \frac{r1}{k1} (3)[/tex]
The ratio of the radii gives
[tex]\frac{r1}{r2} = \frac{k1}{k2} \frac{k2^2-1}{k1^2-1} (4)[/tex]
Having (3) and (4), I just let Mathematica do the rest to solve k1 and k2 for me.
Finally, the voltage difference between the two follows [tex]\frac{q}{2\pi \epsilon L} \ln \frac{k1}{k2}[/tex]
The capacitance per length agrees with Symthe's, which is [tex]\frac{2\pi \epsilon}{arccosh (\frac{a^2+b^2-c^2}{2ab})}[/tex]
woo... beautiful formula. Thx folks.
G.G
