Finding two locations where power out is collision problem
  • Thread starter Thread starter Samuelb88
    Collision Power
The discussion centers on a physics problem involving a collision between a small object and a block attached to a spring, specifically analyzing the power output of the spring at two locations. Given parameters include a small mass of 0.250 kg, a large mass of 3.75 kg, a spring constant of 180 N/m, an initial velocity of 145 m/s, and a coefficient of kinetic friction of 0.600. The correct power output of the spring is determined to be 120 Watts at a position of 0.091 m, contrasting with the incorrect calculations yielding positions of 0.59 m and 1.36 m. The error is attributed to misapplication of the work-energy theorem and misunderstanding of friction's role at maximum compression.
  • Understanding of the work-energy theorem
  • Knowledge of spring mechanics and Hooke's Law
  • Familiarity with power calculations in physics
  • Basic concepts of kinetic friction
  • Review the work-energy theorem in the context of spring systems
  • Study the implications of friction in energy conservation problems
  • Explore the derivation of power output equations for springs
  • Practice solving similar collision and spring compression problems
Students studying physics, particularly those focusing on mechanics, collision problems, and energy conservation principles. This discussion is beneficial for anyone tackling similar homework problems or preparing for exams in classical mechanics.
Samuelb88
A small object is shot into a block that is attached to an ideal spring. After the collision, the block moves over a horizontal surface for which it has friction. The masses of the two objects are given as well as the spring constant of the spring k, the initial velocity of the small object and the coeff. of kinetic friction between the block and the surface.
m (small) = .250 kg
M (big) = 3.75 kg
k = 180Nm^-1
v=145m/s
u_k = .600
(B) Determine two locations of the block (assume that it moves back to the left after it has reached its point of maximum spring compression) when the power output of the spring is 120. Watts.
Power p = (kx)(v)
This was part b of the problem. Part a was to find the max compression of the spring which is x_c (max comp) = 1.23 m.power = 120 W = kx * vx
I used the work-energy theorem to find an expression for the velocity from x_c (max comp) to the point x where the power = 120 W. I ended up with this equation
[tex]K_2 = k \int_{x_c}^{x} x dx - f_kx[/tex]
[tex]= v = (45x^2-11.75x-68.05))^(^1^/^2^)[/tex]
I substituted the value of v into the expression for power which gives
[tex]120 = 180x(45x^2-11.75x-68.05))^(^1^/^2^)[/tex]
squaring both sides, i solve for x and get
x_1 = .59m
x_2 = 1.36
x_3 = negative value.all of which are not correct.
my professor provides one answer and that is the power output of the spring is 120 W at x = .091 m.
i don't quite understand what I'm doing wrong.
There's a problem with [itex]f_k x[/itex] in your equation for [itex]K_2[/itex] The work done by fricton should be 0 when [itex]x = x_c[/itex]
  • · Replies 21 ·
