Forces acting on pipe submerged in drying cement
The discussion focuses on analyzing the forces acting on a hexagonal pipe submerged in drying cement. Key forces include buoyancy, which pushes the pipe upwards, and hydrostatic pressure, which increases with depth. The user confirms that contraction during the curing process is negligible and notes that the expansion and contraction coefficients of concrete and steel are similar, minimizing issues for plastic pipes. Additionally, securing the pipe to steel reinforcement prevents it from floating during the concrete pouring process.
  • Understanding of buoyancy principles
  • Knowledge of hydrostatic pressure calculations
  • Familiarity with material properties of concrete and steel
  • Basic concepts of reinforcement in concrete structures
  • Research buoyancy force calculations for submerged objects
  • Learn about hydrostatic pressure equations and applications
  • Explore the effects of temperature on material expansion and contraction
  • Investigate methods for securing pipes during concrete pouring
Civil engineers, structural designers, and construction professionals involved in concrete applications and pipe installations will benefit from this discussion.
robkm
I need to analyse what's going on when a hexagon pipe is submerged in drying cement.
The pipe is hollow with a thickness and is hexagon shape, where the hexagon is pointing up. It is submerged in standard cement, where the top point of the hexagon is about 100mm from the suface.
I understand when the cement is poured in, buoyancy forces act on the pipe pushing it up. Hydrostatic pressure is also acting on the pipe, imncreasing with depth. is there anything else needed to be considered and how would you calculate the forces.
thanks for any feedback
Pretty sure there is negligible contratction during the curing process. Also with temperature change, the expansion and contraction coefficients of concrete are very similar to steel, and would not usually present a problem to plastic pipes. I have observed that copper pipes are usually wrapped in foam or fabric - but I think that is due to them often being used to convey hot liquids. If the pipe is tied down to say the steel reinforcment, it will not float upwards during the vibration process when the concrete is being poured.
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 20 ·
12K
38K
  • · Replies 52 ·
