Moose352
- 165
Do two observers in different reference frames necessarily agree on the energy of another object in a third reference frame?
The discussion centers on whether two observers in different reference frames agree on the energy of an object in a third reference frame, exploring concepts of energy in the context of relativity, including total energy, kinetic energy, and the implications of General Relativity on energy conservation.
Participants generally agree that energy is not invariant and is dependent on the observer's frame of reference. However, there are multiple competing views regarding the implications of General Relativity and the nature of energy conservation, leaving the discussion unresolved.
Limitations include the dependence on definitions of energy, the unresolved nature of gravitational effects on energy measurements, and the complexity of relativistic effects on energy transfer.
No, the total energy of an object is not an invariant. The total energy equals rest energy (due to the object's mass, an invariant) plus kinetic energy. Since the KE depends on velocity, it and the total energy are frame dependent quantities.Moose352 said:I mean energy as in total energy, including speed, and mass and everything.
Moose352 said:Thanks for the answers. It's pretty interesting that energy is not invariant (you can see it easily from the relativistic energy equation, but I thought my interpretation was wrong).
Garth said:Thank you for that analogy, I shall use it in my lectures if I may. However the question of gravitational red shift may be re-expressed in its terms. If the two observers are both fixed relative to the centre of mass of the system and to each other would they not both see the can from the same perspective? GR would have it that the can rotates when observed from first one and then the other position, but should this be so? Remember that if a particle is 'lifted' out of an atom against the nuclear and electro-magnetic forces then its rest mass increases to include the nuclear and electro-magnetic potential energies. However if you lift an apparatus against a gravitational force then its mass does not increase, according to GR, it is this inconsistency that I question. See my thread "Self Creation Cosmology - a new gravitational theory " https://www.physicsforums.com/showthread.php?t=32713&page=1&pp=15 .
Garth said:Is not the rest mass of a free particle greater than when bound?
The center of momentum frame energy or system mass does not change in the explotion. The total energy does not change. Energy is conserved. As you worded it, it is a "reallocation" of energy from potentials to kinetic. The sum of masses comprising a system can change, changing the sum of kinetic energies of the system. But, the center of momentum frame energy, or system mass, does not change for the system just as the translational kinetic energy "of the system" does not change in the explosion. As invariant, as center of momentum frame energy for a system, is the most useful way to define mass. Without it defined the way it is in modern relativity we never would have arrived at the Klein-Gordon equation modified to include a four-vector potential or the same for the Dirac equation. See equation 3.1.5 and problem 3.1.8 atGarth said:You can always choose a convention in which the allocation of changes in mass and energy are hidden. The question is, "Is this is a useful convention?". In the fission of a uranium atom the reallocation of potential energies releases a hell of a lot of energy and some would say the total mass of the (less-bound) fragments is less than that of the original atom; but if your convention includes this energy in with those fragments as a total system then it tells you that no energy has been released. However, whether this is a useful way to describe the exposion of an atomic bomb or not is debatable to say the least.
Garth said:In my definition of mass,
the mass of a proton (in units of 10^-24 gm) is 1.672661
the mass of an electron is 0.000911
and the mass of a hydrogen atom is 1.67352
which is less than both combined. Hence my point that the mass of a particle is less when bound than when free.
I don't have a problem with calling it as something measured, but even then it shouldn't be referred to as rest mass because you hardly ever measure a particle's mass while it is at rest! You first define it in relation to other quantities like force and acceleration for example and then for an example may put a known charge at a known velocity in a magnetic field which therefor imparts a known force and then measure the radius of the circle to calculate with the velocity an acceleration and from that data actually calulate the mass for its "measurement".Garth said:From your lectures I see that we have a difference of approach that can be expressed as, "Your concept of mass is something that is defined, my concept of mass is something that is measured."
Hence my use of the term "rest mass", which I do not find a confusing term, it is that mass as measured by an observer in the co-moving frame of reference in which it is at rest. It equals the energy-momentum four-vector, which is invariant in all frames of reference in motion relative to that frame.
The mass of a particle does not vary with potential. Imagine what a mess that would be as you can always add an arbitrary constant to a potential. Take a close look at the difference between [tex]p^{\mu }[/tex] and [tex]P^{\mu }[/tex]. The first is the energy-momentum without the inclusion of a potential. The mass is the length of the first. The second includes the potential. The mass is related to it by [tex]m = \frac{\sqrt{g_{\mu \nu}[P^{\mu } - (q/c)\phi ^{\mu }][P^{\nu } - (q/c)\phi ^{\nu }]}}{c}[/tex] where you can see the potential is subtracted back out. The only reason I mention [tex]P^{\mu}[/tex] is because it is actually that four vector that carries the energy and momentum opperators for relativistic quantum mechanics.The question is, nevertheless does mass vary with potential energy?
There is only a problem with development of quantization of gravity itself, not with relativistic quantum electrodynamics which is what these equations are about.Your convention is consistent with the Equivalence Principle, but as the theory derived from the EEP, GR, does seem to have one or two difficulties being integrated with quantum theory I am prepared to question both GR and the EEP on which it is based. See the first question on my first post on the thread "Self Creation Cosmology An alternative gravitational theory".
Not in general. There are some cases when two observers can agree though. E.g. let a free particle (i.e. a particle not subject to any forces) be at rest in the inertial frame S. Let the inertial frame S+ be moving +x direction with respect to S with speed v. Let the inertial frame S- be moving +x direction with respect to S with speed v. Then observers in S+ and S- will agree on the inertial energy (i.e. the sum of the kinetic energy and rest energy) of the particle which is at rest in S.Moose352 said:Do two observers in different reference frames necessarily agree on the energy of another object in a third reference frame?
If the spacetime is stationary then there exists a coordinate system in which the components of the metric tensor are time independent, i.e.Garth said:According to the theory of General Relativity energy-mass is not even conserved.
There is always a gravitational force in GR. It's just not a 4-force, its an inertial force. Also, the presence of a gravitational force does not depend on the presence of spacetime curvature. You can have a gravitational force in the absence of spacetime curvature. For the definition of gravitational force in GR please seeHowever, in GR there is no gravitational force, just the curvature of space-time.
For a closed system, energy is always conserved locally. The complete statement of that fact is given byGR is an example of what Emmy Noether called an 'improper energy theorem', in GR energy is not locally conserved.
The gravitational field does do work. In fact one widely known example is that of gravitational redshift. This is caused by the gravitational field doing work on a photon as it climbs out of the gravitational field.No work is being done on the space-ship or the Earth, there is no force to do any work, and yet the Earth's total energy steadily increases.
Different physicists use the term total energy to refer to different quantities. Some, such as myself, use the term to mean the sum of rest energy, kinetic energy and potential energy. I prefer to call the sum of rest energy and kinetic energy inertial energy or free particle energy (as J.D. Jackson calls it in Classical Electrodyanmics - Second Ed.) so as not to confuse it with total energy. Inertial energy is proportional to the time component of 4-momentum whereas total energy is proportional to the time component of canonical 4-momemtum.Doc Al said:The total energy equals rest energy (due to the object's mass, an invariant) plus kinetic energy.
The proper mass of the particle does not change. However the (relativistic) mass decreases.Garth said:However if you lift an apparatus against a gravitational force then its mass does not increase, according to GR, ..
The rest mass of the particle is the same. The mass of the system changes. For the reason why please see On the concept of mass in relativity at www.geocities.com/physics_world. See the section called "Why does E = mc2" which starts on page 52.Garth said:Is not the rest mass of a free particle greater than when bound?
[tex]g_{\alpha\beta,0} = \frac{dg_{\alpha\beta}}{dt} = 0[/tex]
In such a coordinate system the energy of a particle in free-fall is constant. For proof please see
http://www.geocities.com/physics_world/gr/conserved_quantities.htm
http://www.geocities.com/physics_world/gr/grav_force.htm
[tex]T^{0\alpha}{,\alpha} = 0[/tex]
I was responding to your comment According to the theory of General Relativity energy-mass is not even conserved. That staetment is incorrect.Garth said:The Centre of Mass/Momentum frame.
Now you're speaking of an inertial frame. Yes. There are no gravitational forces in an inertial frame of reference within a restricted region. But you said there are no gravitational forces. Gravitational forces are inertial forces and as such they are frame dependent. They exist only in non-inertial frames such as a frame attached to the surface of the Earth.The Equivalence Principle relies on the fact that to an observer in a freely-falling frame of reference there are no forces acting on a small enough scale - although tidal forces apply to any realistic volume.
The equationIt is energy-momentum that is conserved because of that equation, which is entirely different.
I already explained to you why that is incorrect. You're speaking of four-forces which don't have a relative existence. Gravity is a force and as such it can do work. Just because it can be transformed away it doesn't mean that it isn't a force. It only means that its an inertial force. Curvature has nothing at all to do with this.Really? the photon has no forces acting on it, just the curvature of space-time.
You'd be hard pressed to find a GR text which didn't refer to the components of the metric tensor as gravitational potentials. In fact it was Eisntein himself who called them that. He even called them that in his Nobel Prize acceptance speech - http://www.nobel.se/physics/laureates/1921/einstein-lecture.pdfGR replaces gravitational force with curvature of space-time, as there is no force there is no such thing as potential energy - not according to GR and the EEP that is.
To be consistent to GR and the EEP you cannot select a preferred frame of reference. Statements have to be true of all inertial frames, therefore my statement was a true statement consistent with the theory. To select a preferred frame is exactly what my theory of self creation does, using Mach's Principle to do so, as such it is an alternative theory to GRpmb_phy said:In the case of a finding the energy of a particle as measured in a free-fall frame near a spherical body such as the Earth then no, the energy of a particle, as measured from that frame, is not constant. However the energy of the particle is constant as measured in the frame of reference attached to the surface of the Earth.
My mistake - sorry I read your equation incorrectly. But energy is not locally conserved in general in GR, Einstein was very concerned about this.The equation
[tex]T^{0\alpha}_{,\alpha} = 0[/tex]
is a statement of the conservation of energy. The equation
[tex]T^{k\alpha}_{,\alpha} = 0[/tex]
is a statement of the conservation of the kth component of momentum. The equation
[tex]T^{\alpha\beta}_{,\beta} = 0[/tex]
is the statement of conservation of energy-momentum.
Newtonian gravitational potential is brought into GR only to calibrate the theory so that in the Newtonian limit the two theories agree. Once so calibrated the Newtonian gravitational potential plays no further part, it is replaced by the components of the metric. The temptation always is not to be consistent and work in one theory or the other but to confuse the two. If you are consistent then the problems of GR are not masked but force consideration, if you are bothered to.You'd be hard pressed to find a GR text which didn't refer to the components of the metric tensor as gravitational potentials.
Anyone can, at any time they see fit, choose a particular frame of reference to describe nature. That's what the subscripts/superscripts refer to in the equations of relativity. In SR and GR there are no preferred frames of reference.Garth said:To be consistent to GR and the EEP you cannot select a preferred frame of reference.
No. It wasn't. If you're referring to this theory of yours then that is not GR. I'm speaking of GR and that is all.Statements have to be true of all inertial frames, therefore my statement was a true statement consistent with the theory.
No problemo! We all make mitakes.My mistake - sorry I read your equation incorrectly.
Energy is always conserved locally in GR. Why would you think otherwise? Where did you hear this?But energy is not locally conserved in general in GR, Einstein was very concerned about this.
Who was speaking about a Newtonian gravitational potential? I wasn't.Newtonian gravitational potential is brought into GR only to calibrate the theory so that in the Newtonian limit the two theories agree.
That is why everyone who works in GR refers to the components of the metric tensor as a set of ten gravitational potentials. In GR things are more complicated. Potential *energy* is another concept in GR but it is one which is related to the gravitatonal potential. Gravitational potential energy is energy of position. Change the position of a particle and you've changed the energy of the particle. That is, by definition, a change in potential energy. In GR the energy is not a nice linear sum of rest energy, kinetic energy and potential energy but potential energy is still there. When you use the weak field approximation for GR, its still GR but now you can express the total energy of the particle in terms of potential energy as well as rest and kinetic energy. I can derive this if you'd like but for now I'll simply quote the result from Gravitation and Spacetime - 2nd Ed. Ohanian and Ruffini which is on page 157 in Eq. 101 which reads (Ohanian uses the symbol m for proper mass and sets c = 1 and uses u for 4-velocity)Once so calibrated the Newtonian gravitational potential plays no further part, it is replaced by the components of the metric.
The first term on the right has the form of the usual rest-mass and kinetic energy; the other terms represent a gravitational interaction (potential energy).
The gravitational field transfers energy and momentum to "matter," in that it exerts forces on it and gives it energy; ..
pmb_phy said:Energy is always conserved locally in GR. Why would you think otherwise? Where did you hear this?
Who ever gave you the idea that for something to be conserved it must have the same value in all frames? Energy has always been a frame dependent quantity. Its true in Newtonian physics as well as in SR.Garth said:Energy is not conserved in GR because it is not manifestly covariant, its value is therefore dependent on the frame of reference in which it is measured, ..
Correct. That does not mean that "energy is not conserved".Energy that is seen to be conserved in one frame will not in general be conserved in the other.
pmb_phy said:Who ever gave you the idea
The way you're going here means that everything which is frame dependent (i.e. not covariant) doesn't exist.
In what article or text?Garth said:Albert Einstein?
First let's get the usage of the terminology correct. A quantity like rest mass can't be "manifeslty covariant". The term "manifestly covariant" refers to equations and not to numbers like energy. The term "covariant" can be applied to things like numbers but it has a meaning which is not what you think it has. A number is covariant if its value changes from one frame to another frame.I don't follow you at all, if something is not manifestly covariant it is not that it does not exist, just that its value (mass, time duration, length, whatever) is frame dependent.
