Troubleshooting Guitar Amp Electrical Issues in Apartment
  • Thread starter Thread starter MasterBlaster
    Electrical
The discussion revolves around troubleshooting electrical issues with a guitar amplifier in an apartment setting, specifically focusing on unwanted radio interference and buzzing noises when connected to a computer. Participants explore potential electrical mistakes, grounding issues, and the effects of various equipment configurations.
  • Experimental/applied
  • One participant experiences radio signals coming through the amp's speakers and seeks to identify electrical issues causing this interference.
  • Another participant suggests that isolating the signal ground from the power ground may prevent the chassis from acting as an antenna.
  • There are recommendations for using a grounded outlet and shielded cables to reduce noise.
  • A participant describes a buzzing issue that occurs when the amp is connected to a computer, suggesting that the computer's sound card may be contributing to the problem.
  • Ground loops are identified as a potential cause of the buzzing, with suggestions to use an isolation transformer to mitigate the issue.
  • Questions arise regarding the grounding of the computer and whether the wall outlet is properly grounded, with suggestions to test different outlets.
  • Participants discuss the possibility of other electronic devices in the environment contributing to the noise, such as fluorescent lights or AC hum from monitors.
  • There is mention of using an isolation transformer for audio connections and the potential for flipping polarity switches on the amp to resolve issues.
Participants generally agree that grounding issues and ground loops are likely contributors to the problems described, but there is no consensus on the specific cause or solution. Multiple competing views on troubleshooting methods and equipment configurations remain present.
Participants express uncertainty about the grounding status of their outlets and equipment, indicating that the discussion is limited by the lack of definitive testing results and the complexity of electrical interactions in the apartment setting.
Individuals experiencing similar electrical interference issues with audio equipment, particularly in apartment settings, as well as those interested in troubleshooting audio and grounding problems.
MasterBlaster
When I plug my guitar amp into any outlet in my apt. I get a local radio station coming through the speakers in low volume. If I bypass the speakers and use headphones it still comes in so it will come out of any of the outputs.
Although I have not tested this amp at another place in a long time, I do not believe it to be the amp.
What electrical mistakes/issues could be causing this?
Computer science news on Phys.org
Furthermore - are there any common pieces I can add to the electrical cable plug into stop this? It's something coming through the electrical cable...
Make sure the signal ground is isolated from the power ground... otherwise the chasis will act as one big antenna.
eNtRopY
eNtRopY
Can you explain this in layman's terms?
Thanks!
You should be using a 3-prong (grounded) outlet, do not use an adapter on your power plug that eliminates the round ground pin.
Also, you could try using a different length cable between your guitar and the amplifier input. If you can find a shielded cable for this, that would be better.
Thanks!
There are usually two grounds in an electronic system. One is for power and one is for signal. The power ground is always noisy, and usually the case of the system is grounded to it. The signal ground is a clean ground. It is used as a voltage reference for the music signal. You don't want this ground to be connected to the power ground. It will cause your signal to be noisy, and it is possible that the case will act as an antenna imposing radio signal on your guitar signal.
eNtRopY
So entropy - My issue know lies in the fact that when I have my amp plugged through my system to my PC, I get a buzzing in the amp speakers as well as in the PC speakers.
And when I bypass my computer and just run it to the PC speakers, I don't get the buzz.
This led be to believe that somehow the cheap mobo soundcard or the computer itself is causing this buzzing, however the buzzing also requires my amp to be plugged into the wall. Weather or not the amp is on or not doesn't matter, just that it is plugged in.
SO it's like it requires both those things to buzz.
So I went and got a cheap soundcard to try it. Not only does the buzzing still occur, but when I strum my guitar the monitor get slines on it, and a hard strum causes the monitor to black out and the green light goes yellow for a second.
So what the hell. Either my computer (not the mobo soundcard) is doing it - or the amp is sending some bad power signals into the lines and distorting the damn computer ****.
My only guess is to take the amp into the store. The guy said it didn't sound like my amp was the issue - but i dunno.
Any ideas? I know it's complicated but I am **** out of luck for answers!
Whenever you hear buzzing coming through the speaker, it means you have a ground loop. That is to say that you are grounding your signal electronics with two different grounds in two different places. Since the two grounds have slightly different voltage potentials, there is a DC current passing through your electronics. This current is generating thermal noise.
What you need to do is protect your computer from your amp by using an isolation transformer.
eNtRopY
Ok Entropy - thanks a lot... a bit more questions for your smart brain.
First off catch my other post about this - since I've isolated the issue to much fewer pieces of equipment it may help. Let me know what you think in there as well if you please.
You mentioned the isolation transformer - since in my other post I show that this issue doesn't need to involve the amp at all, let me know what you think about that.
Also - the type of cord i use to run the amp to the PC is a large size jack, the 1/2 inch i guess it is.
Do isolation transfomers fit that? And would they have those at radio shack? thanks!
Question: Is your computer properly grounded? Are you using the third grouding prong on the outlet plug? Are you certain that ground of your wall outlet isn't floating?
All the things you have described so far, in this post and the other, are indications that you have a ground loop in your system. Since, you say that have problems even when you don't plug anything into your computer, I have to wonder if the ground of your computer is floating... that is to say, I have to wonder if your computer is not grounded at all.
eNtRopY
Ok entropy - I am indeed using the third prong of my computer.
Originally I had my PC in one of those power strips to a power plug. Instead I tried putting the power plug into the same outlet that the strip was in.
So this floating issue - is that an issue at each outlet?
Would it be a good idea to try a different outlet? Or would the floating issue be something that would not change at a different outlet.../
Sure, try another outlet. Maybe the wall outlet is floating. If that doesn't work... take two of these and call me in the morning.
eNtRopY
I will try another one and get back to you.
I tried another outlet. Identically the same.
DX posted in the other column trying unplugging each device to see if one is malfunctioning. Since this is easy to do I will go do it now.
But I plan on speaking with the front desk tomorrow - I will tell them "an electrician at radio shack told me it could damage my computer". So it will give them a reason to fix it. At least send an electrician to assess the problem!
Anyhow - with all the ****ing testing I have done I am just going to suck it up if they won't fix it. It has to be inside the walls...
thanks fer all the help entropy
This sounds like a prime candidate for the problem.
Crystal, I'm guessing you could probably get a ground tester at radioshack. If it indicates a bad ground, you may need to rewire your house or at least the outlets you wish to use for this purpose.
***use extreme caution if you try this yourself***
buzzing guitar and computer
Guitars can pick-up the AC humm from a standard PC monitor and put it thru the signal line. Turn volume all the way down on your guitar or turn off your monitor(s) from the front panel, does this change anything? If you have an LCD monitor forget about what I said. Also, are there any touch lites or flourescent lights in the room, maybe on the same breaker? Does the room you play in have a concrete floor? Bare or under carpet? Are you using any effects? Tuners, pedals etc... if so, and they use wall-wart power adapters, try using a 9 volt battery instead of A/C.
The do sell isolation transformers for most audio connectors. Radio Shack might not have them, but a good music store probably will.
All of the items mentioned so far could be causing your issue.
However, the cure might be as simple as flipping the isolation polarity switch on your amp.
If it has one.
Also, you might not need to use the amp if all you are trying to do is get sound in your PC.
Try an adaptor connector and plug guitar directly into sound card.
  • · Replies 21 ·
9K
  • · Replies 79 ·
  • · Replies 165 ·
12K
