Simple differentiation question
  • Thread starter Thread starter semc
    Differentiation
The discussion focuses on calculating the maximum possible error in the area of a Norman window, which consists of a square and a semicircle. The base of the window is 80 cm with a measurement error of 0.1 cm. Two methods were used for differentiation: one using the formula Area = 4r² + 0.5πr² and the other Area = r² + 0.5π(r/2)². The first method yielded an error estimate of 32 + 4π, while the second produced 16 + 2π, leading to confusion about their equivalence. The consensus is that both methods are valid, provided the measurement error in the radius is correctly interpreted as half of the base's error.
  • Understanding of differential calculus
  • Familiarity with geometric shapes, specifically the Norman window
  • Knowledge of error analysis in measurements
  • Ability to differentiate functions involving π
  • Study the principles of differential calculus in error estimation
  • Learn about geometric properties of composite shapes
  • Explore measurement error propagation techniques
  • Review differentiation of functions involving constants like π
Students in mathematics, engineers involved in design and measurement, and anyone interested in understanding error analysis in geometric calculations.
semc
A Norman window has the shape of a square surmounted by a semicircle.
The base of the window is measured as having 80cm with a
possible error in measurement of 0.1cm. Use differentials to estimate
the maximum possible error in computing the area of the window.
So what i did was Area=4r2+0.5[tex]\pi[/tex]r2 differentiated wrt r and sub in value of r=40 and dr=0.1. However i got 32+4[tex]\pi[/tex]. If i were to use Area=r2+0.5[tex]\pi[/tex](r/2)2 and repeat the steps i would get 16 +2[tex]\pi[/tex] which is half of my initial answer. So i want to ask why can't i use the initial method? Ain't the two of them the same?
P/S I wanted to write 0.5(Pi)r^2 not 0.5^Pi(r^2) can't seem to change it. Same for the other equation Pi is not raised to the power
I guess it depends on how you interpret the measurement error. If you say that the base is [tex]80 \pm 0.1 \mathrm{cm}[/tex], then the radius should be [tex]40 \pm 0.05 \mathrm{cm}[/tex]
Well it's not really a question of interpretation, but that's right... if you take into account the fact that the measurement error in the radius is half of the measurement error in the full side length, then you get the same answer no matter which formula you use.
