Strongly connected primitive matrix
  • Context: Graduate
  • Thread starter Thread starter Doom of Doom
    Matrix Primitive
In the discussion, the properties of a primitive, irreducible matrix H are examined, specifically whether Hn-1 contains only positive entries. A primitive matrix is defined as one for which there exists a k>0 such that Hk > 0, indicating that all nodes in the corresponding digraph are reachable from one another. The participant concludes that while Hn-1 may not necessarily be positive, the sum of matrices I + H + H2 + ... + Hn-1 will have all positive entries, affirming the strong connectivity of the digraph.
  • Understanding of primitive matrices and their properties
  • Knowledge of irreducible matrices and strongly connected digraphs
  • Familiarity with matrix exponentiation and its implications
  • Basic concepts of probability in the context of Markov chains
  • Study the proof of properties of primitive matrices in linear algebra
  • Explore the relationship between matrix powers and graph connectivity
  • Learn about Markov chains and their transition matrices
  • Investigate the Perron-Frobenius theorem and its applications to irreducible matrices
Mathematicians, computer scientists, and researchers in graph theory or linear algebra who are interested in the properties of matrices related to connectivity and transition probabilities.
Doom of Doom
If H is a nxn primitive, irreducible matrix, is it always true that Hn-1 > 0? That is, every entry in Hn-1 is positive.
From my class notes, the definition of H primitive is that there exists some k>0 such that Hk > 0. And a matrix is irreducible if its digraph is strongly connected (that is, it is possible to reach every node from every other node in a finite number of steps).
I am interpreting H as a matrix of a strongly connected digraph. Since it is strongly connected, it should be possible to reach any other node after n-1 steps, and thus (H n -1)ij should be positive since there is a positive probability that it will get to node j from node i in n-1 steps.
Is there a good way to prove that every element of Hn-1 must be positive?
Ok, I thought about it a little more. Hn-1 might not necessarily be positive, since it might not be possible to go from i to j in exactly n-1 steps, but it would be possible for some k, 1<k<n-1. Also, the diagonal entries of Hn-1 would not necessarily be positive (if for some node you have to hit every other node before coming back to the original node
Thus, I + H + H2 +... + Hn-1 should have all positive entries.
i.e., if the digraph is strongly positive, it should be possible to get from every node to every other node in at most n-1 steps. Thus, for all i,j, with i[tex]\neq[/tex]j, (Hk)ij must be greater than zero for some k, 1<k<n-1.
How can I prove THIS?
thanks
  • · Replies 0 ·
