| Thread Closed |
torque and angular acceleration..finding coeff. of friction |
Share Thread | Thread Tools |
| Nov26-09, 12:34 AM | #1 |
The problem states: grindstone in shape of solid disk with diameter .52m and mass 52 kg rotates at 850 rev/min. You press an ax against the rim with normal force 160 N and grindstone comes to rest in 7.5 s. Find coefficient of friction between ax and grindstone. 2. Relevant equations The sum of all torques t = I*alpha (angular accel). = alpha*mass*radius^2 avg.angular.accel = (change in angular velocity)/(change in time) 850 rpm = 89 rad/s 3. The attempt at a solution Using Newton's second law I get the sum of external forces = m*a(tangential) = m*r*alpha = (mu)_k*n (mu)_k = (mass*radius*alpha)/n = 0.964 The answer in the book is half of the answer I got, 0.482. Where did I miss this? Thanks so much =) |
| Nov26-09, 12:42 AM | #2 |
Easy, it seems like your moment of inertia is wrong. If I'm not mistaken you're currently using I=MR^2. Which is the moment of inertia for a thin hoop, not a disk.
A disk has the moment of inertia I= (MR^2)/2.... half of what you're using =) |
| Nov29-09, 01:24 PM | #3 |
Thanks, that was a silly mistake.
I feel completely stupid asking this now but i returned to the question and I don't see how I was using moment of inertia to answer my question. It just seems that what I did was solve for ang.accel by taking the change in ang.vel. over change in time to get 11.87 rad/s. Then I equated the sum of ext.forces = f(k) = ma(tangential) = m*r*ang.accel. since f(k) = mu_k*n.... so mu_k = (m*r*ang.accel)/n . Thank you so much, I'm just having a massive mental block. |
| Nov29-09, 11:57 PM | #4 |
Don't worry about it, angular momentum can be a hard concept but I recommend working hard at it. It will come a lot in physics from now on =)
| Thread Closed |
| Thread Tools | |
Similar Threads for: torque and angular acceleration..finding coeff. of friction
| Solve for torque? Torque = Moment of Inertia * Angular Acceleration? | Introductory Physics Homework | 6 | ||
| Torque and Angular Acceleration | Introductory Physics Homework | 1 | ||
| Angular Acceleration: finding the coefficient of friction | Introductory Physics Homework | 10 | ||
| torque/angular acceleration | Introductory Physics Homework | 3 | ||
