An example of a function that attains the value infinity on R?
The discussion revolves around the concept of functions that attain the value of infinity within the context of measure theory. Participants explore examples of such functions, particularly focusing on the behavior of specific functions like 1/x and 1/x² at certain points, as well as the implications of extending functions to include infinity.
  • One participant asks for examples of functions that attain the value of infinity, referencing introductory measure theory texts.
  • Another participant clarifies that for a function to attain the value of +∞, there must exist a real number r such that f(r) = +∞.
  • It is stated that 1/x does not attain the value of infinity at x=0, while 1/x² can be considered to attain it under certain interpretations.
  • A distinction is made between the literal interpretation of functions and the concept of continuous extension, where 1/x² can be defined to be +∞ at x=0 in a continuous context.
  • One participant explains that 1/x does not take on the value of infinity at x=0 due to the behavior of the function around that point, while 1/x² remains positive near zero.
  • A request is made for additional examples of functions that attain the value of infinity within the non-extended real numbers.
  • A specific piecewise function is provided as an example that attains the value of infinity between 1 and 2.
Participants express differing views on the behavior of the functions 1/x and 1/x² at x=0, with some agreeing on the concept of continuous extension while others challenge the definitions and implications of infinity in this context. The discussion remains unresolved regarding the broader question of functions attaining infinity.
There are limitations in the definitions and interpretations of functions at specific points, particularly concerning the extended real numbers and continuous extensions. The discussion does not resolve these complexities.
Readers interested in measure theory, mathematical analysis, or the behavior of functions in relation to infinity may find this discussion relevant.
AxiomOfChoice
An example of a function that attains the value "infinity" on R?
I'm reading a couple of books on introductory measure theory (Royden, Stein-Shakarchi), and both of them talk about functions that can possibly attain the value [itex]\infty[/itex]. But they don't define exactly what this means, or give examples. So can someone list some examples? Does [itex]1/x[/itex] attain the value of [itex]\infty[/itex] at [itex]x=0[/itex]? Does [itex]1/x^2[/itex]? In this sense, is the latter function continuous at [itex]x=0[/itex], whereas the former isn't?
It means, there exists some real number r such that [itex]f(r) = +\infty[/itex].
Your text (surely) has explicitly defined the extended real numbers by now. They are a number system that contains every real number, and two additional numbers they call [itex]+\infty[/itex] and [itex]-\infty[/itex]. There is nothing syntactically special about these two infinite numbers -- they are extended real numbers just like any other extended real numbers.
No.
Yes and no.
Taking this expression literally as expressing a partial function in the extended real variable x, it is undefined at x=0.
However, in continuous mathematics, it is common to take the "continuous extension" of a function. 1/x² has a limit at x=0, and we can define a new (continuous!) function to be 1/x² everywhere else, and to be [itex]+\infty[/itex] at x=0.
It is common to do this continuous extension without explicitly stating it. And in a context like this, I would assume that is what was meant unless it was explicitly stated otherwise. I would expect a good introductory text to at least mention that we often do this...
Anyways, you will eventually be tweaking the definition of "function" so that its values at individual points don't really matter -- so it doesn't really matter if 1/x² is defined at x=0 and what value it might have.
If we desired, we could extend 1/x by defining it to be [itex]+\infty[/itex] at x=0, but it still wouldn't be continuous there.
Note that continuous extension happens in a different way too -- e.g. it would compel us to say [itex]\mathrm{arctan}(+\infty) = \pi/2[/itex] and [itex]\mathrm{arctan}(-\infty) = -\pi/2[/itex].
P.S. Just FYI, I am taking care to write [itex]+\infty[/itex] for the positive infinite number. My reason, which is probably irrelevant to you, is to distinguish it from the projective real numbers which just has one infinite number, which I call [itex]\infty[/itex].
The reason why 1/x does NOT take on the value [itex]\infty[/itex] at x=0, even in the extended real numbers, while 1/x2 does, is that there exist (negative) numbers arbitrarily close to 0 for which 1/x is an arbitarily large negative number, while there are also numbers arbitrarily close to 0 for which 1/x is an arbitrarily large positive number. For x close to 0, 1/x2 is always positive.
Thanks for your help.
Can anyone else provide examples of functions that attain the value [tex]\infty[/itex] at some point in the non-extended real numbers?[/tex]
Example...
[tex] f(x) =\begin{cases}<br /> 0 \text{ if }x<1\\<br /> \infty \text{ if } 1 \le x \le 2\\<br /> 4 \text{ if } x > 2\end{cases}[/tex]
