Arithmetic shift divison question
  • Thread starter Thread starter bitrex
    Arithmetic Shift
The discussion revolves around an arithmetic shift division question, specifically examining an alternative formula for dividing the product of two variables by 255 using bitwise operations. Participants explore the equivalence of this formula to the original division operation, focusing on the implications of using shifts and the conditions under which the formula holds.
  • Technical explanation, Debate/contested, Mathematical reasoning
  • One participant presents a formula that replaces division by 255 with a combination of shifts and additions, seeking clarification on its correctness and mechanics.
  • Another participant challenges the proposed formula, arguing that it does not yield the correct result when one of the variables is zero.
  • A third participant points out that the algorithm fails for certain values, specifically at 65535 and larger numbers, suggesting that the underlying assumptions about fixed-point representation may be flawed.
  • There is a question about whether the variables b and c are integers, with a suggestion that the formula might depend on the two's complement representation of integers.
Participants do not reach a consensus on the correctness of the proposed formula, with multiple competing views on its validity and applicability based on different scenarios.
The discussion highlights potential limitations related to the assumptions about variable types (e.g., integers) and the specific conditions under which the proposed formula may or may not hold true.
bitrex
If I have the following function:
a = b * c/255
The following function is apparently equivalent using only shifts:
product = b * c;
a = (product + (product>>8) + 1)>>8;
I am having trouble following how this function works. Since an arithmetic right shift is division by a power of 2 right shift 8 would be division by 256...somehow (product + (product>>8) +1) is compensating for the difference between the two but I'm not sure why it's that and not just (product + 1). I'm too thickheaded to see it, any clarification would be appreciated!
Technology news on Phys.org
I don't think your formula is correct. For example, if b was 0, then b*c/255 is zero but your replacement formula would not produce 0.
The algorithm fails at 65535 (255*257) and larger numbers.
The algorithm is based on the fact that in hexadecimal fixed point
1/ff = .010101010101 ...
or expressed as a power series:
p/255 = (p/256) + (p/2562) + (p/2563) + (p/2564) + (p/2565) + ...
are b and c integers? this might work if integers are stored as two's complement.
  • · Replies 17 ·
