Thread Closed
Temperature Fusion (heat gain = heat loss)
Share Thread Thread Tools
Nov29-09, 09:11 AM   #1
If 10 kilogram of ice at zero degrees celsius is added to 20 kilogram of steam at 100 degrees celsius, what is the temperature of the resulting mixture?
2. Relevant equations
uhm... perhaps how many solutions are required to arrive at the answer?
3. The attempt at a solution
I and some of my classmates arrived at 16.11 degrees celsius but my instructor said its wrong. He said the answer is around 40 degrees celsius. Now, he gave it as an assignment to us to find the correct solution.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov29-09, 09:14 AM   #2
Admin
In no way that's advanced physics.
Show how you got 16 deg answer. What equations have you used?
Nov29-09, 09:27 AM   #3
Quote by Borek View Post
QE = QA
Heat Evolve = Heat Absorb
MECEdelta TE = MACAdelta TA
Nov29-09, 09:30 AM   #4
Admin
Quote by aodhowain View Post
QE = QA
So far so good.
That's not all.
I have asked you to show how you got the wrong answer.
Nov29-09, 09:46 AM   #5
(10 kg)(0.50 cal/kg*C)(tf - 0C) = (2 kg)(0.48 cal/kg*C)(100C - tf)
5 cal/C * tf = 96 cal - 0.96 cal/C * tf
5.96 cal/C * tf = 96 cal
tf = (96 cal)/(0.96 cal/C)
tf = 16.11 C
Nov29-09, 10:06 AM   #6
Admin
As I told you - you are missing part of the equation. Two parts, to be precise. What you did would be OK for a mixture of water at 0 deg C and water at 100 deg C - but you start with ice and steam.
Nov29-09, 10:23 AM   #7
Recognitions:
Gold Membership Gold Member
I agree. A bit more help, heat from hot water has to be transfered to the ice to melt it, even though the temperature does not change. Quantify this heat.
Nov29-09, 06:03 PM   #8
I think I got the solution to arrive at 40 degrees celsius. Please verify if my answer is correct.
Q out of steam = Q into ice (for c I use kcal/kgC but You can just as easily use J/kgC)
Q out = m*Lv + m*c*deltaT = m*(Lv + c*deltaT) = 2.0kg*(540kcal/kg + 1.0kcal/kg/C*(100-Tf))
Q in = m*Lf +m*c*deltaT = m*(Lf =c*deltaT) = 10kg*(80kcal/kg + 1.0kcal/kgC*(Tf -0))
Setting these equal gives 2.0*540 +2.0*100 -2.0*Tf = 10*80 + 10*Tf
Solving (10+2)*Tf = 2*540 +2*100-10*80 = 480 so Tf = 480/12 = 40degC
Nov29-09, 06:09 PM   #9
Admin
I have just skimmed, looks reasonably.
buffer calculator, concentration calculator
pH calculator, stoichiometry calculator
Thread Closed
Thread Tools
Similar Threads for: Temperature Fusion (heat gain = heat loss)
Thread Forum Replies
Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity Advanced Physics Homework 4
Heat Equation Time dependant heat loss Calculus & Beyond Homework 1
Heat gain or loss by s conductor and an insulator. Advanced Physics Homework 1
specific heat capacity and latent heat of fusion Introductory Physics Homework 4
can the water (100 oC) gain latent heat energy from the same temperature object? General Physics 2
