Stopping Distance Friction Problem
The problem involves calculating the stopping distance of a 1500 kg automobile traveling at 110 km/h on both dry and wet pavement, using the coefficient of friction values provided. The context is rooted in physics, specifically in the areas of kinematics and friction.
  • The original poster attempts to convert speed from km/h to m/s and apply the friction equation to find the normal force. Some participants question the conversion accuracy and suggest using the correct speed value for further calculations. Others indicate the need to find acceleration using the friction force and mass.
The discussion is ongoing, with participants providing guidance on the conversion process and emphasizing the importance of careful calculations. There is no explicit consensus yet, but suggestions for correcting the approach have been made.
Participants note the potential for errors in unit conversion and the importance of understanding the relationship between speed, acceleration, and stopping distance. The original poster expresses uncertainty about their calculations, indicating a need for clarification.
RebelAngel
A 1500 kg automobile travels at a speed of 110 km/h along a straight concrete highway. Faced with an emergency situation, the driver jams on the brakes and slides to a stop.
a) What is his stopping distance on dry pavement (mu = 0.85)?
b) What is his stopping distance on wet pavement (mu = 0.60)?
My instructor gave me this equation to use to solve the problem:
-µFN=max
I first converted km/h to m/s which came out to be 0.533.
I then plugged my numbers into the formula:
-0.85FN=1500(0.533)
and came out with this answer:
FN= -940.6 for a
and
FN= -1332.5 for b
Im not sure where I messed up, but if anyone could help me that would be great!
Thanks!
Welcome to PF!
I first converted 110 km/h to m/s which came out to be 0.533.
Write the 110 km/h, then replace the km with 1000 m and the hour with 3600 s, then run it through your calculator. Should be around 30 m/s.
Of course this is the SPEED, not the acceleration!
Use -µF=m*a to find the acceleration. You can find the normal force from the mass of the car.
Finally, after finding the initial velocity and the acceleration, you'll need an accelerated motion formula to find the stopping distance.
Ah, now i feel blonde, haha. Thanks so much!
I've seen it SO many times! It is worth taking a moment to write out that step where you replace the km and the hr. It makes your work reliable and saves all the time you waste catching the mistakes.
24K
