Does the Volume of a Solid Depend on Point of Tangency?
  • Context: Graduate
  • Thread starter Thread starter iceman
    Solid Volume
The discussion revolves around a mathematical problem concerning the volume of a solid defined by the coordinate planes and a tangent plane to the surface described by the equation xyz = k in the first octant. Participants explore whether the volume depends on the point of tangency and seek clarification on the steps to derive the volume expression.
  • Homework-related
  • One participant requests assistance in demonstrating that the volume of the solid does not depend on the point of tangency.
  • Another participant suggests that the volume is 9k/2 and provides a hint about finding the normal vector using the gradient.
  • A different participant expresses confusion about the problem and requests a step-by-step explanation of how the volume was calculated.
  • One participant outlines a method to find the normal vector and derive the equation of the tangent plane, detailing the steps to calculate the volume of the solid.
  • The final participant thanks the contributor for their help, indicating a collaborative effort in understanding the problem.
Participants do not reach a consensus on the problem's solution, as one participant claims a specific volume while others express confusion and seek clarification on the steps involved.
Participants' responses indicate varying levels of understanding and assumptions about the problem, with some steps in the mathematical reasoning remaining unresolved or unclear to others.
Students or individuals interested in mathematical problems related to geometry, calculus, or solid volumes may find this discussion beneficial.
iceman
Hi,
I need help on this problem which is giving me a few headaches...!
here goes..
Show that the volume of the solid bounded by the coordinate planes and the plane tangent to the portion of the surface xyz = k, k>0, in the first octant does not depend on the point of tangency.
Your help will be much appreciated.
OK, i think i have the answer. i make it 9k/2. how much help do you want?
my first hint: the normal to that surface can be found by taking the gradient.
Hi lethe,
I am totally lost on this question to be honest and I can't seem to work out what to do here to solve it. I would really appreciate it if you could explain step by step what you are doing so I can understand how you came to your conclusion and your answer.
eg. how you came to your answer of 9k/2.
and also your hint: the normal to that surface can be found by taking the gradient.
How would you go about solving this?
Your help will be greatly appreciated.
Thanks.
OK:
step 1: the gradient of xyz - k gives you the normal vector to the surface.
the gradient is (yz,xz,xy)
step 2: the equation for a plane with normal vector n is n*(x-x0)=0
so the equation for the tangent plane at x0 is y0z0(x-x0)+x0z0(y-y0)+x0y0(z-z0)=0
or
x/x0 + y/y0 + z/z0 = 3
step 3: find the three coordinate intercepts of this plane by plugging in x=y=0 and get z=30, then x=z=0 and get y=3y0, and x=3x0
step 4: calculate the volume. it is a right pyramid, the base has legs 3x0 and 3y0, so the area of the base is 9x0y0/2. the area for a pyramid is 1/3*Base*height, so this is 9x0y0z0/2, but since x0 is on the surface, x0y0z0 = k, and we get 9k/2 for the volume
Hey thanks for your help lethe!
Regards
Iceman
15K
