Thread Closed
Elastic Collision and Conservation of Energy
Share Thread
Nov30-09, 12:24 AM   #1
SOLVED
A 120g granite cube slides down a 40 degree frictionless ramp. At the bottom, just as it exits onto a horizontal table, it collides with a 225g steel cube at rest. How high above the table should the granite cube be released to give the steel cube a speed of 185cm/s?
2. Relevant equations
Ug=mgh
K=0.5mv2
P=mv
3. The attempt at a solution
I first calculated the momentum of the steel block (block 2):
P=mv
P2=(.225)(1.85)
P2=0.41625kg*m/s
Then, using conservation of momentum I deduced that the momentum of the granite block (block 1) before the collision must be equal to the momentum of the second block after the collision (P1=0.41625kg*m/s). Using this I can find the velocity of block 1 just before the collision:
P=mv
0.41625=(0.120)v
v=3.46875m/s
Now I can find the kinetic energy of block 1 right before it hit block 2:
K=0.5mv2
K=0.5(0.120)(3.46875)2
K=0.722J
Since energy is conserved, Ug at the top of the ramp is equal to K at the bottom of the ramp (Ug=0.722J). We can now find the height of the block:
Ug=mgh
0.722=(0.120)(9.8)h
0.722=1.176h
h=0.6139m=61.39cm
Where did I go wrong?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Thread Closed
Similar discussions for: Elastic Collision and Conservation of Energy
Thread Forum Replies
Conservation of Momentum Elastic Collision Problem Introductory Physics Homework 5
Elastic collision with conservation of energy and momentum? Introductory Physics Homework 5
Conservation of Momentum (Elastic Collision) Introductory Physics Homework 3
Need clarification: conservation of kinetic energy (elastic collision) Introductory Physics Homework 1
[SOLVED] Conservation of momentum + elastic collision Introductory Physics Homework 2
