Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Nuclear Medicine Share It Thread Tools Search this Thread image
Old Nov30-09, 03:21 AM                  #1
dreiter
dreiter is Offline:
Nuclear Medicine
I have heard this title bandied around now for awhile, and I'm still not quite sure what it means? Would this be designing/building/maintaining 'nuclear' machines such as MRI/CT machines, or would this be radiation based treatments for diseases, or would this be (insert job description here)?
Old Nov30-09, 04:21 AM                  #2
fatra2
fatra2 is Offline:
Re: Nuclear Medicine
Hi there,
MRIs are not "nuclear machines". They are calle Magnetic Resonance Imagery for a reason, because they don not use any nuclear technology.
The term nuclear medicine implies radiation therapy, essentially. Your function will vary essentially according to your level of education. But, the term nuclear medicine does not refer to the design, construction, nor maintenance of the nuclear instruments. It only refers to the use of these instruments for radiation therapy.
Cheers
Old Nov30-09, 04:28 AM                  #3
dreiter
dreiter is Offline:
Hence my use of single quotes around the word 'nuclear'. :)
I am finishing up my B.S. in engineering physics, and I am looking into the nuclear masters program, but the job market seems uncertain (as far as working at a plant goes). Perhaps the thread should be moved because I have a new question, and that is:
What masters degree is best for working in industry designing/building new CT machines, etc.?
Old Nov30-09, 04:56 AM                  #4
fatra2
fatra2 is Offline:
Hi there,
The best way to truly find out what the industry wants would be to get in contact with some firms that make these instruments. Send them an e-mail.
Otherwise, I would say that nuclear engineering is probably a safe bet, probably more in the field of nuclear instruments. I would say that your knowledge of nuclear physics has to be more or less deep. Your knowledge of material and interaction between radiation and matter is probably where you want to look.
Hope this helps.
Cheers
Old Nov30-09, 09:08 AM                  #5
vibjwb
vibjwb is Offline:
Nuclear medicine has to do with imaging inside the body.
http://en.wikipedia.org/wiki/Nuclear_medicine
Old Dec1-09, 12:42 AM                  #6
Tsu
Tsu's Avatar
Tsu is Offline:
Recognitions:
PF Contributor PF Contributor
Nuclear Medicine is just one area of Diagnostic Imaging. They inject radioactive isotopes into the body that are specifically tagged to go to where you want them. Liver, heart stomach, bone... Then you are scanned with a gamma camera or some other type of tracer - depending upon the exam being done. Positron Emmision Tomography (PET scanning) is part of Nuc. Med. It is a very interesting imaging modality...
Old Dec1-09, 01:43 AM                  #7
dreiter
dreiter is Offline:
Thanks vibjwb for the link. I thought to check Wiki about an hour after I posted the topic, hehe.
I seem to get conflicting info on nuclear medicine as a career choice. Is there pre-med, med school, and a residency involved? I see that the career pays well, so I assume med school is required...
Old Dec1-09, 02:23 AM                  #8
fatra2
fatra2 is Offline:
Hi there,
From my point of view, we gave a few ideas of what is nuclear medicine. Now, if you really want to know more about it, make an appointment with the nuclear department in your hospital. They will be able to show you around, and explain you the details of their function.
That's what I did at the time, just to find out that nuclear medicine was not my cup of tea.
Cheers
Old Dec1-09, 03:07 AM                  #9
alxm
alxm is Offline:
Recognitions:
Well, actually they're called 'Magnetic Resonance Imagery' for the reason that patients didn't want to get into a big machine named 'nuclear'-anything. So they got together and decided (I think it was 1983 or thereabouts) to officially rename it 'MRI' rather than 'NMRI'. NMR machines are still named NMR though. (since test-tubes don't complain)
However I agree it doesn't use 'nuclear technology' in the popular sense and MRI wouldn't fall into the 'nuclear medicine' category.
Old Dec1-09, 03:12 AM                  #10
fatra2
fatra2 is Offline:
Hi there,
You got me stumped with your description. From what I know, MRI are simple big "magnets" of around 1T, that interact with the magnetic particles of the body. Now, could you tell me what part of super-conductivity of a solenoid is part of nuclear.
Cheers
Old Dec1-09, 06:26 AM                  #11
alxm
alxm is Offline:
Recognitions:
The 'particles' in question being the atomic nuclei that have a non-zero net magnetic moment. (notably hydrogen)
Nothing. The magnet is just there to create a field. The field's not what's being measured though. The field causes an energy level splitting (Zeeman effect) which is what the nuclei 'resonate' between. Superconductors are used because it's the only viable way to achieve field strengths of that order. It doesn't need to be a superconducting solenoid. The first NMR machine used a big permanent magnet.
It's 'nuclear' because you're measuring a property of the nuclei. Not a molecular or atomic or electronic property but a specifically nuclear one - the nuclear spin state interacts only very weakly with the electrons, and hence chemistry is unaffected and it's all an entirely noninvasive method. (which was first used for chemistry as NMR, and still is, with higher resolution machines and fields typically about 10-13T)
Old Dec1-09, 05:40 PM                  #12
chemisttree
chemisttree's Avatar
chemisttree is Offline:
Recognitions:
Homework Helper Homework Helper
Nuclear Medicine pamphlet. Salary of the typical nuclear medicine technologist is $64K. A doctor specializing in nuclear medicine makes about 400K. But doctors specalizing in orthopedics make about 500K on average. http://www.cejkasearch.com/compensat...ion_survey.htm
Old Dec1-09, 10:28 PM                  #13
Tsu
Tsu's Avatar
Tsu is Offline:
Recognitions:
It depends upon whether you want to be the technologist who actually performs the exam (approx. $30-$40/hr) or if you want to be the physician who interprets the exam (potentially up to $500,000/yr). Radiologists interpret Nuc.Med. studies. Radiologists are MD's who have specialized in Diagnostic Imaging. Tech school = approx. 2 yrs; Radiologist school = pre med, med school, internship and then several years of Radiology Residency. Fellowship? = more years of school.
I have been working in the field of diagnostic imaging for 35 years. I do xrays and cat scan exams, although Nuc Med is a very interesting area with PET scanning technology growing in leaps and bounds. PET scanning (positron emmision tomography) is a fascinating cross of Nuc Med and CT technology.
image image
Reply
Thread Tools
Similar Threads for: Nuclear Medicine
Thread Thread Starter Forum Replies Last Post
Clinical Faculty: Internal Medicine, Family Medicine, Primary Care - Position # 39324 Greg Bernhardt Science Jobs 0 Dec10-08 05:00 PM
What is the link between nuclear weapons and nuclear power stations? strongmotive Nuclear Engineering 19 Sep22-08 07:06 AM
Nuclear Medicine? godwinscareer Academic Guidance 1 Jan8-08 05:34 PM
What medicine Joeyluvluv Medical Sciences 2 Jan27-05 04:16 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
