Center of the Univers
by The Grimmus
Tags: univers
Hurkyl
Hurkyl is offline
#235
Jul10-03, 05:55 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
What is a field if it is not defined in terms of space? Therefore if space is expanding then so is the field.
Fields don't have length, area, or volume. There is no distance between fields. What expands?
(in the above I mean those words and phrases simply don't have a meaning, not that those things have zero value)
It is a mathematical abstraction that mathematically patches two inconsistent models together. This abstraction has zero evidence for it's assumptions.
Which is why GR and the Standard Model are actually used to describe the universe, and string theory is still a research project.
(by the Standard Model, I mean the quantum theory with that name, not whatever you call the standard model)
Brad_Ad23
Brad_Ad23 is offline
#236
Jul10-03, 05:58 PM
P: 499
Good job Hurkyl.
subtillioN
#237
Jul10-03, 06:35 PM
P: n/a
Fields have no extension? Says who?
Again, says who? If they exist in space then they have extension in all three dimensions.
The whole commonly used model is the standard model.
subtillioN
#238
Jul10-03, 06:50 PM
P: n/a
Originally posted by Hydr0matic
I disagree. I find his arguments concrete and accurate. It is you, subtillioN, that strikes me as the fanatic one defending your faith. More than anything else, you just seem interested in convincing others you're right.
A belief in spite of evidence is faith. I find it fun to see if you people can stretch your minds far enough to see a better theory.
But as Planck said it is quite difficult indeed.
"new scientific theories supplant previous ones not because people change their minds, but simply because old people die" - Max Planck
[:D]
You people only respect the revolutions after they have happened. You have no clue of the ones currently under way and you don't want to know.
Hurkyl
Hurkyl is offline
#239
Jul10-03, 07:15 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
I've never seen anyone suggest defining area or volume for a field... nor define length in a way that has anything to do with lengths in space.
Let's consider a simple example of fields f and g on the differentiable manifold R:
f: x -> 1 / (1 + x2)
g: x -> (sin x) / x
So what is the length of f? What is the distance between f and g? And if you can give me meanings for these, please explain how they have any relation to lengths in R.
Which seems to me precisely how hydr0matic used the word. [;)]
Show me a success of a theory and I'll consider it. Until then, I'll continue my path towards learning what I need to be able to study LQG.
Hydr0matic
Hydr0matic is offline
#240
Jul10-03, 07:28 PM
Hydr0matic's Avatar
P: 199
"you people" ? [s(] .. So you presume that I'm narrow-minded just because I don't believe plasma-"theory" is correct ? Be honest, do you consider yourself open to the possibility that plasma-"theory" might be incorrect ?
[:D]
Yes, old people are very set in their ways. I'm 21 on the other hand and very open to new good ideas. I haven't read a lot of plasma-"theory", but at first glance, it doesn't qualify as such.
I don't understand how you can be so confident in your beliefs. You seem deluded [:D] [;)].
Anyway, I think I'll try and jump in now... First question:
Since plasma-theory dismisses the expansion of space, how does it explain the redshift-distance relation ? I didn't seem to find that answer on the site...
Since there's only an inherent and a velocity component, then objects further away from earth must be younger ? .. right ? [8)] .. but that doesn't make sense, because if the objects furthest away were very young, we wouldn't be able to see them.
subtillioN
#241
Jul10-03, 09:21 PM
P: n/a
lol! oh so you simply assume that they have no extension since you have never seen anyone plot it mathematically? Think for yourself man!! Obviously if it exists in space and is not a point then it must have extension.
I am tired of showing it to you and you just ignoring it.
Go your own way and don't bother with this Plasma Cosmology nonsense. I don't need to waste any more time.
subtillioN
#242
Jul10-03, 09:35 PM
P: n/a
No. It's because you seem believe that it is incorrect without studying it.
Yes I certainly do and I believe that ALL theories are incorrect to a degree. Some more than others.
One of my motivations is to see if the people on this site can find holes in it, but I can't get any one to even find it to find the holes. All we seem to do is argue banalities that don't even relate to the model. Oh well. I thought it was an easy read but apparently it is quite difficult for some people to get through.
on first glance? you proved my point...
This is because you don't know what my beliefs are. They are quite different from yours I can assure you that.
The velocity to distance maping is proven to give incorrect results. See: http://www.electric-cosmos.org/arp.htm
As for the source of the red-shift see this:
http://www.newtonphysics.on.ca/hydrogen/index.html
and the 3k CBR:
http://www.newtonphysics.on.ca/COSMIC/Cosmic.html
Well that is what BBT says, but the fact is that the galaxies at the very limits of perception are exactly the same statistically as those in our immediate vicinity. This gives those "edge" galaxies time for a mere 2 or 3 rotations since the big bang.
for but that doesn't make sense, because if the objects furthest away were very young, we wouldn't be able to see them.
Well I don't get your point here except maybe that there should be "embryonic" galaxies (if any at all) at the "edges" of the known Universe instead of fully mature ones containing the older second generation blue stars.
Hurkyl
Hurkyl is offline
#243
Jul10-03, 09:56 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
Open your mind to the alternatives. [:)]
How would you ascribe an "extension" to:
f(x) = 1 / (1 + x2)
Fields are not points, curves, surfaces, or solids. Fields are an assignment of one or more quantities to every point in space. There is no reason to presume "extent" makes any sense when talking about fields.
Sometimes those quantities will come equipped with their own metric, but that metric is internal to the range of quantities and has absolutely no relationship to the metric on space. Measurement of "distance" between quantities has no bearing whatsoever on distances in space... and besides, the metric on the quantities is usually taken to be fixed and unchanging.
I am tired of showing it to you and you just ignoring it. Go your own way and don't bother with this Plasma Cosmology nonsense. I don't need to waste any more time.
I'm tired of you thinking you've showed successes when you've showed only speculation. Go away and don't bother us with your Plasma Cosmology nonsense. You don't need to waste any more time! [;)]
subtillioN
#244
Jul10-03, 10:25 PM
P: n/a
f(x) = 1 / (1 + x2)
Why would I ascribe extension to an equation?
You are confusing mathematics with reality.
[zz)]
Hurkyl
Hurkyl is offline
#245
Jul10-03, 10:35 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
As I stated before, there is little in which to punch a hole.
Crackpots seem to miss the fact that in order to have a testable theory, they have to do more than say "this is how things work"; they have to be able to say "this is how things work and here is the mathematical derivation of quantities you have and will observe".
Crackpot theories also tend to be paired with an insatiable drive to show that mainstream physics is incorrect (and their attempts are often laughably poor). The reason is usually clear; their theories are totally inconsistent with the way mainstream physics says things should work, often both in the qualitative aspect and at the fundamental level. Since crackpot physics are often so strongly at odds with the way physics is believed to work, one should argue the "banalities" because it is quite frequently a very quick way to find out that a crackpot theory is internally inconsistent.
Crackpots that take up that attempt at proving modern physics incorrect overlook yet another thing; the only way to replace a theory of how the universe works is to produce a model that can make more and better predictions than the old model. This is why there is the demand for precise numerical computations of everything; mainstream physics HAS a model that can compute a great many things, with great accuracy. If your trying to replace an aspect of mainstream physics, but your model can't compute what the current model can compute, then your model is of little use to mainstream physics. This is why revolutions occur so infrequently; it is extraordinarily difficult to come up with a model that has everything and a bag of chips; instead tweaks are made to the existing model.
So, basically, there are only two ways to get a model seriously considered by mainstream physics:
(a) Have a theory that supplements the existing model.
(b) Have a theory that (precisely and numerically) predicts (nearly) everything the existing model can predict.
Incidentally, I do have another hole to poke into the electric sun model. Even if we suppose that the sun had a net positive charged and that is what allows it to resist gravitational collapse... that would not reduce the tremendous pressures in the depths of the sun; pressures strong enough to ignite and sustain fusion in just the same way it happens in the fusion model. (which would subsequently blow the star to smithereens because the combination of electrostatic repulsion and radiation pressure, both strong enough to resist gravity on their own, would completely overwhelm gravity's ability to keep the star together)
Hurkyl
Hurkyl is offline
#246
Jul10-03, 10:36 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
Because that equation is an example of a field. You said fields have extent, didn't you?
How so?
subtillioN
#247
Jul10-03, 10:41 PM
P: n/a
How so?
"Because that equation is an example of a field."
Hurkyl
Hurkyl is offline
#248
Jul10-03, 10:47 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
A field is mathematics. It appears that you are the one confusing mathematics with reality! (whatever that's supposed to mean) [:D]
subtillioN
#249
Jul10-03, 10:51 PM
P: n/a
Ok so this does not apply to plasma physics because you failed to show that the mathematics is incorrect. Well and to be fair, you failed to find the mathematics... well and you failed to even find the explanations... and you failed to understand the theory that you continue to dismiss.
Just as the copernican model was inconsistent with the way physics thought things work... and not to mention relativity theory and quantum mechanics....
You never debated the theory at all. You got lost in pointless details that were about the STANDARD model. you never discussed the internal properties of the Plasma model whatsoever.
such as Plasma cosmology which can explain many things that the standard model can't.
so nothing revolutionary please... we like it just the way it is...
How about one that predicts and explains much more?
That is a joke right? How can you prove mathematically that this would happen. Give me a break. PURE erroneous speculation.
subtillioN
#250
Jul10-03, 11:02 PM
P: n/a
I am talking about a REAL field in REAL space such as a magnetic or electric field. Do you really think that a REAL field is made out of numbers and equations?
Hurkyl
Hurkyl is offline
#251
Jul10-03, 11:07 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
But there are differences!
(a) The heliocentric model explains precisely why the geocentric model was thought to be correct, and makes identical observational predictions.
(b) Special relativity explains precisely why newtonian mechanics was thought to be correct, and makes predictions indistinguishable from those of Newtonian mechanics in the domain where Newton has been verified. Special relativity also presented numerous precise numerical predictions that could be tested by subsequent experimentation.
(c) General relativity explains precisely why special relativity and Newtonian gravitation were thought to be correct, and makes predictions indistinguishable from those of the aforementioned theories in the domain where they were verified... corrected a few flaws in the old theories, and has presented numberous precise numerical predictions that could be tested by subsequent experimentation.
(d) Quantum mechanics (relativistic QM) explains precisely why newtonian mechanics (special relativity) was thought to be correct. On the domains where newtonian mechanics (special relativity) have been tested, QM makes indistinguishable predictions. QM has made numerous precise numerical predictions that could be tested by subsequent experimentation.
Not one of these theories said "Pah, mainstream physics is wrong, here's how things really are!"; each and every one agrees indistinguishably from the theory it relpaced on the scales the replaced theory was tested.
One could ask the same thing about all of your posts.
Hurkyl
Hurkyl is offline
#252
Jul10-03, 11:12 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
A field one of many mathematical abstractions that describe our observations. What we call a "magnetic field" is most certainly something made out of numbers and equations.
Anyways, if there is some "real" entity that corresponds to the mathematical abstraction we call a "magnetic field"... and that "real" entity has an extent, then would we not ascribe that extent to the "magnetic field" corresponding to that entity?
Register to reply
Related Discussions
Center of gravity (it's not center of mass!!!) General Physics 28
the geometric center of the Earth and the center of mass Classical Physics 9
u think that the univers is realy expanding?? think again Cosmology 10
Can two objects with the same center of mass oscillate about that center? Introductory Physics Homework 0
The center of Mass perfectly match the center of Force-> General Physics 9
