Thread Closed
Non inverting op-amp
Share Thread Thread Tools
Dec1-09, 12:47 PM   #1
Calculate the out put voltsge on the amplifier with a voltage supply of Vs 100 mV and Rs = 1k , R1=1k R2=10k. power comes from a +-15 v supply
2. Relevant equations
V1-V2/r1+V1-V2/R2=0
V+=V-
3. The attempt at a solution
it is the Risistor Rs that i am have trouble with since V+=V- on an op amp if i can find V+ then i think it can be done.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Dec1-09, 02:34 PM   #2
Mentor
Quote by weedannycool View Post
V1-V2/r1+V1-V2/R2=0
V+=V-
You correctly list V+ = V- which is true because of the high open loop gain of the opamp. The resistor Rs doesn't really do much in this circuit, since the input current of the opamp can be assumed to be negligible in a problem like this.
So you are given Vs, which goes right into the V+ input. What voltage will you therefore have at the V- terminal? From there, it's just a voltage divider problem, right?
Dec1-09, 02:38 PM   #3
thanks very much.
did u like my diagram?. definatly not going to be an artist. haha
Dec1-09, 02:49 PM   #4
Mentor
thanks very much.
Hey, it worked for me. And thanks for posting with the HH Template and showing your work. Made it much easier to help you out. Welcome to the PF!
Thread Closed
Tags
analysis, circuit, op amp
Thread Tools
Similar Threads for: Non inverting op-amp
Thread Forum Replies
inverting op amp circuit Electrical Engineering 12
Non Inverting and Inverting Amplifiers Introductory Physics Homework 1
Op Amp inverting amplifier , help! Engineering, Comp Sci, & Technology Homework 1
Current in a non-inverting amp. Introductory Physics Homework 0
Inverting 3 by 3 matricies Linear & Abstract Algebra 9
