Distance of Closest Approach of Two Particles
  • Thread starter Thread starter nothilaryy
    Approach Particles
The discussion revolves around finding the distance of closest approach, or impact parameter, between two particles given their momenta and possibly their charges. The context suggests a connection to special relativity, though the original poster expresses uncertainty about the relevant equations and concepts.
  • The original poster attempts to relate the problem to concepts of energy and momentum conservation, while also seeking resources to better understand the mathematics of special relativity. Participants question the clarity of the problem description and the assumptions regarding the relativistic nature of the scenario.
The discussion is ongoing, with participants seeking clarification on the specifics of the problem, including the types of particles involved and their initial conditions. There is a recognition of the need for more concrete information to proceed effectively.
There is ambiguity regarding the definitions of certain symbols, such as 'x' and 'q', and whether the problem indeed requires a relativistic approach. The original poster expresses a lack of clarity about the problem setup and the necessary calculations.
nothilaryy
Given the momentum p1 and p2, find the distance of closest approach (b) also known as the impact parameter. I think we are also given charges q because I later have written solve for b2 in terms of x2, q2, P2, p[tex]\bullet[/tex]x, q[tex]\bullet[/tex]x, and p[tex]\bullet[/tex]q. [those are supposed to be dot products but I think I fail at latex] I believe x is supposed to be relative position.
I'm not really sure which equations I'm supposed to be using at all, but my best guess is to use
E = mc2
E2= E'2 - (pc)2
and maybe the lorentz transformations?
Ok so here's the deal. As much as I'd like an answer to this problem, I'd like to really understand what is going on much more. I've essentially been thrown into the world of special relativity without so much as a textbook for a side project I'm doing for a professor, and I understand the theory behind this weird stuff like time dilation and etc, but I don't understand most of the math behind it. So if anyone happens to know of a good online resource for this sort of stuff, I would greatly appreciate it.
That being said, I have actually given the problem a try! According to the hint my professor gave us, I'm supposed to solve it in the reference frame of the velocity of the center of mass, but I'm not really sure how to go about that. I thought about finding the center of mass like I would in mechanics, but not only can I not find enough information to be able to do that, I routinely mess up when I try to apply mechanics ideas when working with relativity.
I also looked at https://www.physicsforums.com/showthread.php?t=161767", because it seems really similar, but I cannot seem to convert between the information I was given and the information they were given. I did gather that I should be conserving total energy and momentum, but again, I'm not sure where to go from there.
Sorry for this wall of text- even the littlest bit of help or nudge in the right direction would be appreciated.
Can you be more specific with the description of the problem? You are looking for the impact parameter, but what kind of particles do you have and what are the initial conditions? Also you seem to imply that the calculation needs to be relativistic. What is the evidence that it is?
Uhm all I was definitely given were that there are two particles each with some momentum (and possibly some charge). The only reason why I think its supposed to be relativistic is because that's what we were going over before the problem was assigned? I really wish I could be less vague, but truth be told I'm not all that clear on the problem myself. Sorry if this problem is just way too not concrete.
It is "way to not concrete". It is also not clear what the symbols x and q stand for. If q is a charge (a scalar) then a term like q . x makes no sense as a dot product.
