Thread Closed
sufficient conditions for a = lim inf xn
Share Thread Thread Tools
Dec1-09, 06:51 PM   #1
This is part of a theorem which is left unproved in "Elementary Classical Analysis" by Marsden and Hoffman.
Let xn be a sequence in R which is bounded below. Let a be in R.
Suppose:
(i) For all e > 0 there is an N such that a - e < xn for all n >= N.
(ii) For all e > 0 and all M, there is an n > M with xn < a + e.
Show that a = lim inf xn.
(Definition: When xn is bounded below, lim inf xn is the infimum of the set of all cluster points of xn. If xn has no cluster points, then lim inf xn = + infinity. If xn is not bounded below, then lim inf xn = - infinity.)
I was able to use (i) and (ii) to show that a is the limit of a subsequence of xn, hence a is a cluster point. So to show that a = lim inf xn, it is sufficient to show that a is a lower bound for the set of cluster points. This is what I can't do. Any suggestions?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec2-09, 11:44 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Well, suppose b < a is a cluster point. Doesn't that give you a problem with (i).?
Dec2-09, 12:18 PM   #3
So I set e = a - b in (i) and get b < xn for all n>=N. I don't see the problem with this.
I think this implies all cluster points x satisfy b <= x, which means b <= a, but now I'm back where I started.
Dec2-09, 12:41 PM   #4
Recognitions:
Try e = (a - b)/2. Can't you show all but finitely many of the xn are bounded away from b?
Dec2-09, 01:45 PM   #5
I think I get it now.
Setting e = (a -b)/2 in (i) gives (a + b)/2 < xn for all n >= N
==> (a - b)/2 < xn - b for all n >= N
==> no subsequence of xn can converge to b, since (a - b)/2 > 0
==> b is not a cluster point.
thanks!
Thread Closed
Thread Tools
Similar Threads for: sufficient conditions for a = lim inf xn
Thread Forum Replies
What's the difference between initial conditions and boundary conditions? Differential Equations 9
necessary and sufficient conditions: Fourier Transform Calculus 5
sufficient statistic Set Theory, Logic, Probability, Statistics 3
Sufficient model, or...? Differential Equations 1
necessary and sufficient condition Linear & Abstract Algebra 4
