| Thread Closed |
Water Flow in pipes - urgent |
Share Thread | Thread Tools |
| Dec3-09, 06:15 AM | #1 |
Water is flowing through a pipe whose radius is 0.04m with a speed of 15m/s. The same pipe goes up to the second floor of the building, 3m higher, and the pressure remains unchanged. What is the radius of the pipe on the second floor? EDIT: NVM, SOLVED! Here's the solution anyways 1/2(15^2) + 9.8 * 0 = 1/2(v^2) + 3 * 9.8 solve for v then put v into (.04^2 * pi) * 15 = (r^2 * pi) * v pi cancels and tada u get r = 0.043m |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Water Flow in pipes - urgent
| flow through parallel pipes with different diameters | Engineering, Comp Sci, & Technology Homework | 2 | ||
| what rate does water flow through the pipes? | Introductory Physics Homework | 5 | ||
| Water flow in pipes | Engineering, Comp Sci, & Technology Homework | 0 | ||
| [SOLVED] Water flow in pipes | Introductory Physics Homework | 5 | ||
| More on flow through pipes | Mechanical Engineering | 1 | ||
