Solve Physics Problem: Heat Conducted Through 2 Rods
This discussion details the calculation of heat conduction through two rods, one aluminum and one copper, joined end to end. Using the Fourier law of heat conduction, the thermal conductivities for aluminum (205 W/mK) and copper (385 W/mK) were applied to determine the heat conducted in 2 seconds. The total heat conducted through both rods was calculated to be 0.904 watts. The methodology included calculating the change in temperature and applying the thermal resistance concept for series barriers.
  • Understanding of Fourier law of heat conduction
  • Knowledge of thermal conductivity constants for materials
  • Familiarity with the concept of thermal resistance
  • Basic algebra for solving equations
  • Research the thermal conductivity constants of other materials
  • Learn about the applications of thermal resistance in engineering
  • Explore advanced heat transfer concepts such as convection and radiation
  • Study the effects of temperature gradients on heat conduction
Students in physics or engineering, thermal engineers, and anyone interested in heat transfer principles and calculations.
Mathwizard6254
Two rods, one of aluminum and the other of copper, are joined end to end. The cross-sectional area of each is 4.0 x 10^-4 m^2, and the length of each is 0.040m. The free end of the aluminum rod is kept at 302 degrees Celsius, while the free end of the copper rod is kept at 25 degrees Celsius. The loss of heat through the sides of the rods may be ignored. How much heat is conducted through the unit in 2 seconds? Please show the work done in solving this problem. THank you very much!
You should show what work you have done so that people can help you understand it better. To solve this problem, you'll need to look up the thermal conductivity of each material involved. The following equation defines the rate of conduction heat transfer through a barrier (aka Fourier law of heat conduction - I think my notation is standard or at least self-explanatory; I hope you can follow it):
[tex]q = \frac{Q}{t} = kA\frac{T_2 - T_1}{L}[/tex]
When dealing with a series of barriers as in this case, it is useful to consider the concept of a thermal resistance (analagous to electrical resistance):
[tex]R_{th} = \frac{L}{kA}[/tex]
Then you can sum the resistances that are in series to find:
[tex]\frac{Q}{t} = \frac{\Delta T}{\Sigma_i{R_{th, i}}}[/tex]
(For this problem, you'll want to solve for Q.)
To solve this physics problem, we will use the equation for heat conduction:
Q = kAΔT / L
Where:
Q = heat conducted
k = thermal conductivity constant (depends on the material)
A = cross-sectional area
ΔT = change in temperature
L = length
First, we need to find the thermal conductivity constant for aluminum and copper. According to the table of thermal conductivity constants, the thermal conductivity constant for aluminum is 205 W/mK and for copper is 385 W/mK.
Next, we can calculate the change in temperature (ΔT) for each rod:
ΔT(aluminum) = 302°C - 25°C = 277°C
ΔT(copper) = 302°C - 25°C = 277°C
Now, we can plug in the values into the equation:
Q(aluminum) = (205 W/mK)(4.0 x 10^-4 m^2)(277°C) / 0.040m = 569.25 W
Q(copper) = (385 W/mK)(4.0 x 10^-4 m^2)(277°C) / 0.040m = 1058.5 W
Since the two rods are joined end to end, the heat conducted through both rods will be the same. Therefore, we can add the two values together to get the total heat conducted:
Q = 569.25 W + 1058.5 W = 1627.75 W
Finally, we need to convert the unit of time from seconds to hours, since the thermal conductivity constants are given in W/mK. There are 3600 seconds in 1 hour, so we can calculate the heat conducted in 2 seconds as:
Q = (1627.75 W)(2 s) / (3600 s/h) = 0.904 W
Therefore, in 2 seconds, 0.904 watts of heat will be conducted through the two rods.
10K
  • · Replies 41 ·
10K
