Max Height Homogenous Differential Equation
The discussion revolves around solving a second-order homogeneous differential equation with initial conditions. The equation is given as y" + y = -sin(2x), and participants are exploring the maximum value of the solution y based on the initial conditions y(0) = 0 and y'(0) = 0.
  • Participants discuss the derivation of the general solution and the particular solution, questioning the application of initial conditions. There is an exploration of the maximum value of the function derived from the differential equation.
Some participants have pointed out the need to consider the general solution rather than just the particular solution. There is an ongoing clarification regarding the constants involved in the general solution and how they relate to the initial conditions.
Participants note that the initial conditions apply to the general solution, which includes both the complementary and particular solutions. There is a recognition of potential mistakes in the application of these conditions.
shards5
Let y be the the solution of the initial value problem. The maximum value of y is?
y" + y = -sin(2x)
y(0) = 0
y'(0) = 0
N/A
Factor out original equation to find general equation.
r2 + 1 = 0
r = 0 + i; 0- i
Thus the general solution is.
y(x) = c0cos(x) + c1sin(x)
y'(x) = -c0sin(x) + c1cos(x)
Using the initial conditions I found that.
c0 = 0
c1 = 1
Now to find A*cos(2x) + Bsin(2x)
yp = A*cos(2x) + B*sin(2x)
y'p = -2A*sin(2x) + 2B*cos(2x)
y"p = -4A*cos(2x) - 4B*sin(2x)
Plugging into the original equation we get.
-4A*cos(2x) - 4B*sin(2x) + A*cos(2x) + B*sin(2x) = -sin(2x)
which gives us with -3Bsin(2x) = -sin(2x) B = 1/3 and A = 0
Therefore the equation is.
y(x) = 1/3*sin(2x)
To find the maximum value I do the derivative of the above equation and set it equal to zero.
y'(x) = 2/3*cos(2x) = 0 which gives x to be pi/4
Using x = pi/4 in the unique equation.
y(pi/4) = 1/3*sin(2*pi/4)
I get y = 0.333333333333333 which is wrong, of course.
So what am I doing wrong?
You're working only with the particular solution, not the general solution. Your general solution is y(x) = sin(x) + (1/3)sin(2x). Find the maximum value of that function.
I made a mistake c1 is supposed to also equal zero so my particular solution would only have 1/3sin(2x).
The initial conditions are for the general solution y(x), not just for the complementary solution. Start with a general solution of y(x) = c0cosx + c1sinx + (1/3)sin2x and calculate the constants c0 and c1 using your two initial conditions.
  • · Replies 20 ·
  • · Replies 18 ·
