Solving KE for a Bead Rolling Along an Ellipse Using Lagrange's Method
  • Context: Graduate
  • Thread starter Thread starter elegysix
    ellipses
This discussion focuses on deriving the kinetic energy (KE) of a bead rolling along the bottom half of a frictionless ellipse using Lagrange's method. The user is considering two forms of KE: KE = (m/2)(\dot{r}^2 + r^2\dot{\phi}^2) and KE = (m/2)(\dot{x}^2 + \dot{y}^2), where the position vector is defined in terms of polar coordinates. The consensus is to utilize the first equation for KE, transforming it into generalized coordinates for accurate results in Lagrangian mechanics.
  • Understanding of Lagrangian mechanics
  • Familiarity with polar and Cartesian coordinate systems
  • Knowledge of kinetic energy expressions in classical mechanics
  • Ability to perform calculus, particularly differentiation
  • Study the derivation of Lagrange's equations from the Lagrangian function
  • Learn about transforming coordinates in mechanics, specifically from Cartesian to polar
  • Explore examples of kinetic energy in generalized coordinates
  • Investigate common pitfalls in applying Lagrange's method to constrained systems
Students and professionals in physics, particularly those studying classical mechanics, as well as engineers and mathematicians interested in the application of Lagrangian dynamics to constrained motion problems.
elegysix
I'm trying to find the equation of motion of a bead, which is constrained to roll along the bottom half of this frictionless ellipse, by using langrange's method - [tex]L(\phi,\dot{\phi})[/tex].
Here's the setup:
given the bottom half of an ellipse:
[tex]\mathbf{r}(\phi) = acos(\phi)\mathbf{\hat{i}}-bsin(\phi)\mathbf{\hat{j}}[/tex]
where [tex]0<\phi<\pi[/tex], and [tex]\mathbf{\hat{i}}[/tex] , [tex]\mathbf{\hat{j}}[/tex] are the unit vectors for x and y, and [tex]\phi[/tex] is measured from the positive x-axis counterclockwise.
my question is should I use
1) [tex]KE=\frac{m}{2}(\dot{r}^{2}+r^{2}\dot{\phi}^{2})[/tex]
or
2) [tex]KE=\frac{m}{2}(\dot{x}^{2}+\dot{y}^{2})[/tex]
where [tex]\dot{x} \:\&\: \dot{y}[/tex] come from [tex]x=acos(\phi)[/tex] , and [tex]y=-bsin(\phi)[/tex]
which one?
I'm confused because I have polar type coordinates, [tex]r(\phi)[/tex] in terms of Cartesian components.
Assuming that the second equation for KE is not appropriate to use here,
If I use the first the first equation for KE, then is it 'Legal' to find and use [tex]\mathbf{\dot{r}}[/tex] like this? or is this wrong?
[tex]\mathbf{\dot{r}}=-a\dot{\phi}sin(\phi)\mathbf{\hat{i}}-b\dot{\phi}cos(\phi)\mathbf{\hat{j}}[/tex]
As my only other option I'm aware of, I know that the definitely correct, brute force approach looks like this:
[tex]\mathbf{r}(\phi)_{polar}=|\mathbf{r}(\phi)_{cartesian}|\mathbf{\hat{r}}=\sqrt{a^{2}cos^{2}(\phi)+b^{2}sin^{2}(\phi)}\mathbf{\hat{r}}[/tex]
which means we're in polar coordinates, so
[tex]\mathbf{\dot{r}}(\phi)=\dot{r}\mathbf{\hat{r}}+r\dot{\phi}\mathbf{\hat{\phi}}[/tex]
[tex]\mathbf{\dot{r}}(\phi)=\frac{d(\sqrt{a^{2}cos^{2}(\phi)+b^{2}sin^{2}(\phi)})}{dt}\mathbf{\hat{r}}+\dot{\phi}\sqrt{a^{2}cos^{2}(\phi)+b^{2}sin^{2}(\phi)}\mathbf{\hat{\phi}}[/tex]
and L=KE-PE... and then I have to solve [tex]\frac{dL}{d\phi}-\frac{d(\frac{dL}{d\dot{\phi}})}{dt}=0[/tex]
which, that route is becoming a nightmare very quickly, and I don't want any trouble with the algebra police... any advice?
The idea in these types of problems is to find an expression for the KE purely in terms of your generalized coordinates. Sometimes you may know the KE immediately in those terms, but other times you may have to start from Cartesian coordinates where you know the expression for KE and then you can transform to your generalized coordinates.
That is a long-winded way of saying that I would start with 2) and substitute in the a cos and b sin terms.
  • · Replies 16 ·
