Determine the mass per unit length of the string.
The discussion revolves around determining the mass per unit length of a guitar string based on its tension, length, and fundamental frequency. The problem is situated within the context of wave mechanics and string vibrations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between tension, frequency, and wavelength, with one participant questioning how to determine the wavelength. Another confirms that the wavelength is twice the length of the string at its fundamental frequency.
Some participants have provided guidance on potential errors in calculations, such as unit conversions and the squaring of frequency. There is an ongoing exploration of the correct application of the formula without a clear consensus on the final answer.
Participants note the importance of converting measurements from centimeters to meters and the need to apply the formula correctly, indicating that assumptions about the wavelength may need to be revisited.
chess10771
A guitar's E-string has length 65 cm and is stretched to a tension of 85 N. It vibrates at a fundamental frequency of 329.79 Hz. Determine the mass per unit length of the string.
1Your answer is in kg/m
(mass per unit length) = (tension) / ((frequency)x(wave length))^2
The tension is 85 N, and the freq is 329.79 Hz, and how do i figure out the wave length, it thought the wavelength was twice the e string length in cm.
Yes, wavelength is twice the string length because the string is vibrating at its fundamental frequency.
ok, i get an answe 1.5e-5 but its not correct am i doing something wrong
I think you forgot to convert cm to m, and you didn't square the value for frequency. Using that formula you are supposed to get a value of 4.6e-4 kg/m, correct me if I'm wrong.
  • · Replies 29 ·
  • · Replies 23 ·
