Estimating cost due to power (application of electric current)
The discussion revolves around estimating the energy loss due to heat in a copper wire delivering power to a small city. The problem involves calculating the cost associated with this energy loss, given specific parameters such as power requirements, wire dimensions, and voltage levels.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between wire resistance, power loss, and heat generation. There are inquiries about relevant equations, such as those relating voltage, current, and resistance. Some participants question the assumptions made regarding the voltage drop and the treatment of the wire's cross-sectional area.
The discussion is active, with participants providing various equations and methods for calculating energy loss. There is an exchange of ideas regarding the correct application of formulas, and some participants express uncertainty about their calculations and the assumptions they have made.
Participants mention specific values for resistivity and dimensions of the wire, as well as the cost of electricity, which are critical for the calculations. There is also a note about the appropriateness of posting in the Homework Help forum, indicating awareness of forum guidelines.
Theelectricchild
I would like to understand this problem a bit better...
A small city requires 10 MW of power. Suppose that instead of using high voltage lines to supply the power... the power is delivered at 120 V. Assuming a two wire line of 0.50 cm diameter copper wire, estimate the cost of the energy lost to heat per hour per meter. Assume the cost of electricity is about 10 cents per kWh.
Heres what I am wondering: Should I find the area of the wire (using pi*diameter^2 all over 4) and and then use Ohms Law to solve for the amount--- knowing that V = 120?
Thanks for your help.
Do you have an equation that relates the heat released by a resistor and the voltage, power, or energy being sent through it?
Well, I don't know what equation I should use to include heat.
energy consumed by resistance
First determine the current that must flow through those wires to deliver the stated power.
Then figure out the energy lost in the resistance of the wire as that current flows through it. (You'll need to figure the resistance of the wire.) The power consumed by the resistance is [itex]P = V_{drop}I = I^2R[/itex].
(Please post these kind of questions in the Homework Help forum!)
Doc Al, thank you, and I apologize for posting in this part of the forum I won't do it again.
I seem to get an answer of $841.50! this is interesting--- would you say this is about right using the method you were suggested?
According to http://www.allmeasures.com/Formulae/static/formulae/electrical_resistivity/12.htm, [itex]\rho _{copper} = 16.8 n\Omega \cdot m[/itex]. I don't know why I missed how to do this question (of course, you don't need any formula to calculate heat from energy as I suggested, the heat is the energy!). Anyways:
[tex]R = \frac{\rho _{copper} \times 1m}{2\pi (0.0025m)^2}[/tex]
[tex]P = V^2R[/tex]
[tex]E = P \times 1\ hour[/tex]
The cost, in dollars, is then E/10, as long as E is expressed in kWh. Your numbers look pretty different from mine. What do you have for the resistivity of copper?
1.68e-8 ohms meters is correct, however i am wondering about your 2 times A in the denominator--- should it not be (rho*L)/A then that times 2? Then take that multiply by 120^2
Then take that answer divide by 1000 and then by 10 to get the answer?
the answer is 1190--- btw its I^2 * R hehe, but thank you your explanation is perfect.
You're right, I meant P = V²/R. Doing it this way, you don't even have to calculate current. And the 2A in the denominator seems right. Essentially, you're treating the two wires as one wire with double the cross-sectional area.
If you use [itex]P = V^2/R[/itex], V must be the voltage drop across the wire. This is not 120V.
Treating the two wires as a single wire with double cross-section won't work: Your value for resistance will be a factor of 4 too low.
Oh, I see. My mistakes.
is it meant that P=V^2/R ?
how this equation come from ?
