Register to reply
Moment of Inertia and torque?
by miamirulz29
Tags: inertia, moment, torque
Share this thread:
miamirulz29
#1
Dec6-09, 04:22 PM
P: 62
The combination of an applied force and a frictional force produces a constant total torque of 39.9Nm on a wheel rotating about a fixed axis. The applied force acts for 4.5s, during which time the angular speed of the wheel increases from 3 rad/s to 12 rad/s. The applied force is then removed. The wheel comes to rest in 72s.
A. What is the moment of inertia of the wheel? Answer in units of kgm^2
B. What is the magnitude of the frictional torque? Answer in Nm
C. What is the total number of revolutions of the wheel?
2. Relevant equations
[tex]\sum[/tex][tex]\tau[/tex] = I(moment of inertia) * [tex]\alpha[/tex]
3. The attempt at a solution
A. 39.9 = 2I
I = 19.95
That is correct.
B. T = (19.95)(9/72) = 2.49375
That is incorrect. What am I doing wrong?
C. I need some help, do not know where to start.
Thanks in advance.
Sorry if the equations look bad. This the first time I am using Latex and I still don't know exactly how to use it correctly.
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
miamirulz29
#2
Dec6-09, 04:29 PM
P: 62
Well I just I figured out Part b. Instead of doing 12-3/72, I had to do 12/72. Can somebody explain that to me please.
nrqed
#3
Dec6-09, 04:33 PM
Sci Advisor
HW Helper
P: 2,887
Quote Quote by miamirulz29 View Post
You need to consider the part of the motion when only the frictional torque is acting. The wheel then slows down from 12 rad/s to 0 rad/s in 72 sec. This is why you need to divide 12 rad/s by 72 s to get alpha
miamirulz29
#4
Dec6-09, 04:34 PM
P: 62
Oh right, thank you. Any help for part C? Just a way for me to get started please.
nrqed
#5
Dec6-09, 04:37 PM
Sci Advisor
HW Helper
P: 2,887
You're welcome.
First you need to find the total angle of rotation during the acceleration part and during the deceleration part (you must have seen the formula [itex] \theta = \omega_i t + 1/2 \alpha t^2[/itex]). Then add the two angles for the total angle and fivide by 2 Pi to get the number of revolutions
miamirulz29
#6
Dec6-09, 05:38 PM
P: 62
So could I do this: theta = (1/2)(12/72)(72^2) for the decelerating part and for the accelerating part could I use the other formula: 12^2 - 9^2 / 2(12-3/4.5). Then add those together and divide by 2pi?
nrqed
#7
Dec6-09, 06:36 PM
Sci Advisor
HW Helper
P: 2,887
For the decelerating part, you are missing one term since omega_i is not zero.
For the accelerating part, it sounds good except that you mant 3^2 instead of 9^2.
miamirulz29
#8
Dec6-09, 06:41 PM
P: 62
Yes I meant 3^2 instead of 9^2. But isn't omega_i zero because is it come to rest when it decelerates.
nrqed
#9
Dec6-09, 07:04 PM
Sci Advisor
HW Helper
P: 2,887
It comes to rest at the end of the decelarating part so omega final is zero. But when it started decelarating, its omega was 12 rad/s, so that's the value of omega_i for the decelerating pat
Register to reply
Related Discussions
Solve for torque? Torque = Moment of Inertia * Angular Acceleration? Introductory Physics Homework 6
Moment of Inertia and Torque Introductory Physics Homework 4
Torque and moment of inertia Introductory Physics Homework 6
Moment of inertia / torque question Introductory Physics Homework 9
Torque and Moment of Inertia Introductory Physics Homework 5
