Instantaneous Rate Word Problems
  • Context: Undergrad
  • Thread starter Thread starter leibnitz2001
    Rate
The discussion focuses on two instantaneous rate word problems involving a conical tank draining and the relative motion of a submarine and a destroyer. The first problem requires calculating the rate at which the water level falls when half the water has drained, while the second problem involves determining the separation rate between a submarine and a destroyer after half an hour. Participants emphasize the necessity of using basic differentiation rules without employing the chain rule or trigonometric differentiation. The discussion highlights the importance of visual aids, such as diagrams, in solving these types of problems.
  • Understanding of basic differentiation rules (product, sum, difference, quotient)
  • Knowledge of related rates in calculus
  • Familiarity with geometric properties of conical shapes
  • Ability to interpret and set up word problems in calculus
  • Study the application of related rates in calculus problems
  • Learn how to derive formulas for volume and surface area of conical shapes
  • Practice solving instantaneous rate problems without using the chain rule
  • Explore visual problem-solving techniques, such as drawing diagrams
Students studying calculus, particularly those focusing on related rates, as well as educators looking for effective teaching strategies for complex word problems.
leibnitz2001
1. Water is draining out of a conical tank at a constant rate of 4 feet cubed per minute. Before the tank began draining, the depth of water was 12 ft and the diameter of the waters surface was 8 ft. How fast will the water level be falling when half the water has drained from the tank?
2. A submarine passes directly beneath an enemy destroyer. The sub is 200 ft below the surface of the water, moving northeastward at 40 mi per hour. The destroyer is sailing due south at 25 mi per hr. At what rate will the vessels be seperating after 1/2 hour?
I have figured out a solution for the first problem, but for some reason, even after several attempts, the answer did not match that in the book.
The second problem has given me a little more problem in that I cannot find a proper set up for the problem.
Note that also, these problems are to be done without use of the chain rule or trigonometric differentiation: all that is at your disposal are the basic product, sum, difference, quotient rules of differentiation.
For differentiating a cube root function, this equation comes in handy, which is derived from the product rule:
If f(x)=cube root of g(x), then f'(x) equals g'(x)/(3 times cube root of g(x)^2)
I am interesting in some other solutions to these problems you might be able to provide.
Thanks
Have you tried drawing a picture?
As I said, I have found solutions to both of the problems. The issue is that my answer is not matching that with the book, despite the fact that I have redone the problems numerous times.
  • · Replies 28 ·
