Elastic Collision between a neutron and helium nucleus.
The discussion focuses on an elastic collision between a neutron and a helium nucleus, where the helium nucleus has a mass four times that of the neutron. The neutron, with an initial speed of 6.2 x 105 m/s, collides with the helium nucleus, which is initially at rest. The helium nucleus rebounds at an angle of 41° from the neutron's initial direction. The objective is to determine the rebound angle of the neutron, θ'1, and the speeds of both particles post-collision using the principles of conservation of momentum and conservation of energy.
  • Understanding of elastic collisions in physics
  • Knowledge of conservation of momentum principles
  • Familiarity with conservation of energy equations
  • Basic trigonometry for angle calculations
  • Study the equations governing elastic collisions in two dimensions
  • Learn how to apply conservation of momentum in both x and y directions
  • Explore detailed examples of neutron interactions in nuclear physics
  • Investigate the mathematical methods for solving systems of equations in physics
Students studying physics, particularly those focusing on mechanics and nuclear interactions, as well as educators looking for examples of elastic collisions in their curriculum.
nocho8
A neutron collides elastically with a helium nucleus (at rest initially) whose mass is four times that of the neutron. The helium nucleus is observed to rebound at an angle θ'2 = 41° from the neutron's initial direction. The neutron's initial speed is 6.2 x10^5 m/s. Determine the angle at which the neutron rebounds, θ'1, measured from its initial direction.
__°
What is the speed of the neutron after the collision?
_____m/s
What is the speed of the helium nucleus after the collision?
_____m/s
Wound up with a very messy system of equations involving conservation of momentum in both the x and y directions as well as conservation of energy. Any help would be greatly appreciated!
Can you show some details of what you did? Then perhaps someone will be able to find if you did go wrong and where.
