How Does a Frictionless Piston Behave in a Vacuum-Sealed Cylinder?
  • Thread starter Thread starter itr
The discussion focuses on the behavior of a frictionless piston in a vacuum-sealed cylinder, specifically deriving equations related to pressure, restoring force, and oscillation frequency. The equilibrium pressure of the gas is determined using Boyle's Law, expressed as PV = k. The restoring force equation is derived for small displacements, leading to a differential equation that describes the motion of the piston. It is concluded that the angular frequency of oscillation, denoted as omega, is independent of the mass of the piston, with a specific calculation provided for a cylinder volume of 2000 liters and a cross-sectional area of 1E-4 meters squared.
  • Understanding of Boyle's Law (PV = k)
  • Basic principles of mechanics (force, equilibrium)
  • Knowledge of differential equations
  • Familiarity with oscillatory motion concepts
  • Study the derivation of pressure equations in thermodynamics
  • Learn about differential equations in mechanical systems
  • Explore the principles of oscillation and angular frequency
  • Investigate real-world applications of frictionless pistons in engineering
Physics students, mechanical engineers, and anyone interested in the dynamics of gas systems and oscillatory motion in sealed environments.
itr
A frictionless piston of mass m is at a precise fit in the vertical cylinder neck of a large container of volume V. The container is filled with a gas and there is a vacuum above the piston. THe cross sectional area of the neck(and thereby the piston) is A.
a) Derive an equation for the pressure of the gas in the container when the piston is in equilibrium.
b) Assuming that the pressure and volume of the gas are related by boyle's law, derive an equation for the restoring force on the piston when it is displaced by a small amount of x.
c) assuming that the motion of the piston is small enough for boyle's law to be valid, obtain the differential equation for small displacements of the piston about its equilibrium position.
d) show that the angular frequency of oscillation, omega, is independent of m.
e) calculate omega for V=2000 liters and A= 1E-4 meters squared.
I am not to sure where to begin...I know boyle's law is PV = k where...
P denotes the pressure of the system.
V is the volume of the gas.
k is a constant value representative of the pressure and volume of the system
If you could help me in a direction to go that would be great thank you
does anyone know what to do?
  • · Replies 67 ·
12K
