Does Calcium Build Up on Metal Enhance Corrosion?
The discussion centers around the effects of calcium buildup on metal surfaces, particularly regarding its potential to enhance corrosion. Participants explore various scenarios, including exposure to different environments such as outdoor conditions and aqueous systems, and consider the implications for both visual appearance and structural integrity.
  • Some participants question whether calcium buildup increases the likelihood of corrosion or accelerates it, while others suggest it may be generally harmless.
  • One participant notes that calcium and silicon in aqueous systems contribute to scale, which can reduce heat transfer efficiency and potentially drive corrosion due to increased local temperatures.
  • Another participant clarifies that in a non-aqueous environment, calcium buildup might primarily affect visual appearance rather than significantly impacting the metal's integrity.
  • Concerns are raised about the effects of environmental factors such as humidity and the presence of corrosive species like chlorides, which could lead to pitting or perforation of metal surfaces.
  • It is mentioned that calcium deposits in a shower head can degrade performance and lead to clogs or leaks, indicating a practical application of the discussion.
Participants express differing views on the impact of calcium buildup on corrosion, with some suggesting it may not be harmful in certain environments while others highlight potential risks associated with environmental exposure. The discussion remains unresolved regarding the overall effects of calcium on metal surfaces.
The discussion does not reach a consensus on the conditions under which calcium buildup may or may not affect corrosion, and there are varying assumptions about environmental factors and their implications for metal integrity.
VooDoo
Hey Guys,
Just curiosity, but if a metal surface has a build up of calcium does this mean there is a higher chance of corrosion occurring? Or can it accelerate corrosion? Or is the build up on the surface of metal generally harmless?
VooDoo said:
Hey Guys,
Is this a heat transfer/heated surface?
Ca and Si (in aqueous systems) contribute to scale, and over time on a heated surface, they can reduce heat transfer coefficient and increase local temperature, which further drives corrosion.
Corrosion (conversion of metal to metal oxide) are driven by temperature and availability of oxygen at the metal/oxide interface.
Thanks for the reply. The piece of metal has just been exposed to the outside environment and is not in a aqeuous environment.
So would it be correct to say that the build up of calcium has no major negative effect on the metal besides maybe effecting its visual apprearance?
Whereas a shower head which is in a aqeous environment can be effected by calcium deposits due to the increased chance of corrosion?
So it's not in water, but outside, it is exposed to humidity, condensation, rain?
Well, depending on temperature swings and other corrosive species like Cl or NaCl, it could eventually shorten the service life, especially if it is load bearing.
Any scale may harbor moisture and other corrosive species, such as chlorides. Local deposits could lead to pitting and perhaps perforation of a metal sheet, depending on thickness.
Ca salt deposits or scale in a shower head usually degrades performance, and can clog the spray head, or cause leakage around bushings or moveable joints.
24K
