| New Reply |
Why don't heavy objects fall more SLOWLY? |
Share Thread | Thread Tools |
| May11-12, 10:29 AM | #137 |
| May11-12, 10:51 AM | #138 |
[tex]d_r = v_0 t - \frac{1}{2} a_r t^2[/tex]. Now, up till now, the object was in contact with the base of the rocket, so it also had a velocity of [itex]v_0[/itex]. However, once it loses contact with the ship, it will keep travelling at that velocity until it makes contact again. So the distance that the object travels in the same time [itex]t[/itex] is simply: [tex]d_b = v_0 t[/tex]. If the chamber where the object is had a length [itex]l[/itex], and [itex]t[/itex] was the time it took for the object to travel to the other end, then the object would have to travel a distance of [itex]d_r + l[/itex] to make contact with the other side of the rocket (since both the ends of the chamber will have moved the same distance). So setting those equal: [tex]d_b = d_r + l[/tex] Replacing [itex]d_b[/itex] and [itex]d_r[/itex] with the formulas and solving for [itex]l[/itex]: [tex](v_0 t) = (v_0 t - \frac{1}{2} a_r t^2) + l[/tex] [tex](v_0 t) - (v_0 t - \frac{1}{2} a_r t^2)= l[/tex] Collecting terms and simplifying: [tex](v_0 - v_0) t + \frac{1}{2} a_r t^2= l[/tex] [tex](0) t + \frac{1}{2} a_r t^2= l[/tex] [tex]\frac{1}{2} a_r t^2= l[/tex] Solving for [itex]t[/itex]: [tex]t= \sqrt{\frac{2 l}{a_r}}[/tex]. Note that this doesn't depend on either the mass of the object or the velocity that it and the rocket are travelling at when the acceleration changes. |
| May11-12, 02:39 PM | #139 |
Imagine you are in a ship floating in space with a ball in the center of a room just floating there. You fire your thrusters at a constant rate until the ball hits the side of the room. The rate of acceleration is independent of the mass of the ball because the ball is NOT having any work done upon it until it hits the wall. If I were an observer floating next to you looking in the window I would NOT see the ball move at all while the ship moved around it until it touched the wall. This is exactly the same as when we stop firing the thrusters and begin to decelerate. As soon as the thrusters stop firing, neither the ship nor the ball are accelerating any longer. They are in the same situation as the above example, except with the ball floating at one edge of the room instead of the center. When I begin to fire my thrusters and decelerate the ship, I am NOT doing anything to the ball until it reaches the other side of the room, at which point it will touch the wall and we will have to expend energy to accelerate it as well, at which point it's mass comes into play. |
| May11-12, 02:50 PM | #140 |
| May11-12, 03:07 PM | #141 |
What is mass if it is not the resistence to a force applied. |
| May11-12, 03:34 PM | #142 |
| May11-12, 05:09 PM | #143 |
| May11-12, 05:12 PM | #144 |
| May11-12, 06:53 PM | #145 |
| May11-12, 11:51 PM | #146 |
[tex]F = ma[/tex] The accelration only depends on the total force applied and on the mass that is being accelerated. Since there is no force on the ball when not in contact, it will not be accelerated, so the only thing being accelerated is the ship. Since the only thing being accelerated is the ship and the thrusters have the same force in both cases, it will have the same acceleration in both cases until the ball hits the other side. |
| May12-12, 02:51 AM | #147 |
| May12-12, 10:40 AM | #148 |
| May12-12, 12:31 PM | #149 |
| New Reply |
| Thread Tools | |
Similar Threads for: Why don't heavy objects fall more SLOWLY?
| Law of universal gravitation - why DON'T heavy objects fall faster in a vacume | General Physics | 9 | ||
| free fall with heavy box | Classical Physics | 14 | ||
| Shipping very heavy objects??? | General Discussion | 36 | ||
| Scientists levitate heavy objects | General Physics | 2 | ||
