Gravity Force Calculation: m1, m2 & r^2
  • Context: High School
  • Thread starter Thread starter mrjeffy321
    Gravity
The discussion revolves around the calculation of gravitational force using the formula F = (G * m1 * m2) / r^2. Participants explore how the force of attraction is distributed between two masses and the implications of Newton's Third Law in this context.
  • One participant questions whether the gravitational force calculated is shared between two bodies or if each experiences the full force independently.
  • Another participant clarifies that according to Newton's Third Law, the same magnitude of force acts on both masses due to their mutual attraction.
  • A subsequent reply reinforces that both masses experience the same force, confirming the initial participant's understanding.
  • Further discussion highlights that force equations describe the forces acting on a specific body, emphasizing the importance of isolating a body for analysis.
Participants generally agree that both bodies experience the same gravitational force, as supported by Newton's Third Law. There is no indication of disagreement on this point.
The discussion assumes a basic understanding of gravitational force and Newton's laws, but does not delve into the implications of varying masses or distances beyond the provided example.
This discussion may be useful for individuals interested in gravitational physics, particularly those seeking clarification on force interactions between masses.
mrjeffy321
just a really question about gravity, using the formula:
F = (G * m1 * m2 ) / r^2
where F is the force of attraction caused by gravity, G is the gravitational constant (6.673E-11), m1 is the first mass, m2 is the second mass, and r is the radius/distance between the two centers of mass.
the force that is caused, is it shared between the two bodies or do each receive that much force, for example if I just stick these numbers in:
m1 = 1000000
m2 = 1000000
r^2 = 125
then I get a force of .53384 Newtons
so do each of these bodies recievce the full .53384 Newtons, or does it split up bwtween them and each gets half, .26692?
The force is on one body M_1 due to the nearby presence of another body M_2. Newton's Third Law then states that the same magnitude of force acts on M_2 due to the presence of M_1.
so that formula finds the force that is applied on the first mass (but we know that the second mass gets the same force too).
so in the example I gave earlier, they would both get the 53384 Newtons.
thanks, that solved my problem
Yep.
By the way, this is generally true of all force relationships. Whenever you see [tex]F = ...[/tex], then this is the force acting on the body in question (which we call the "system").
So you always isolate a body to analyze the forces that act on it. The force equations (such as F = mg, F = kx, and so on) describe the magnitudes of the forces that act on THAT body.
  • · Replies 51 ·
  • · Replies 19 ·
  • · Replies 33 ·
