Thread Closed
Material Thickness
Share Thread Thread Tools
Dec16-09, 02:22 PM   #1
Material Thickness
1. A conductive sheet of material has a CSA of 10mm x 20mm. Reisistivity of 103 (10 to the 3, 10,000) ohms M. Calculate thickness of the material required to give resistance of 5k ohms
2. Ro = RA/l , where l would be thickness, l = RA/Ro
3. Thickness = 5,000 x 0.2 / 10,000 = o.1m therefore 100m
Comments appreciated
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec16-09, 06:32 PM   #2
Mentor
There are some problems with your calculation:
103 is not 10,000.
The area is not 0.2 (is that supposed to be in m2?). Try converting the mm values to meters first. Remember, 1 mm is 10-3 m.
Dec18-09, 01:03 PM   #3
Quote by Redbelly98 View Post
103 is not 10,000.
Thickness = 5,000 x 0.0002/ 1,000 = 1 x 10-3m therefore 1mm
or do I have to sq the .ooo2 giving:
=5,000 x 4x10-8 / 1,000 = 2 x 10-7
Dec18-09, 06:20 PM   #4
Mentor
Material Thickness
One of those is correct! Here are 2 questions to help you decide which:
1. How did you get the 0.0002 value for the area, and therefore what are the units associated with this value?
2. Are these units (from my previous question) correct units for an area, or would you need to square the units to to get an area?
Note: correct units for area can be expressed as m2, m·m, mm2, or mm·mm.
Dec19-09, 08:22 AM   #5
Hi, thanks for the reply, think I am having a christmas moment.
The area should be 10mm x 20mm = 200mm in m 200 x 10-3 therefore 0.2m
Thickness = 5,000 x 0.2/ 1,000 = 1mm
How does this seem
Dec19-09, 08:53 AM   #6
Mentor
Quote by Kev1n View Post
The area should be 10mm x 20mm = 200mm ...
I'll stop your post here and make a comment about units.
Just as you multiplied 10 x 20 to get 200, we also need to multiply mm x mm, (since mm appears twice in the values being multiplied) and that gives us mm2. So the units will be mm2, not simply mm as you wrote.
Since mm2 is a unit of area, we have A=200 mm2 for the area. Do not square this value to do the calculation; that would result in units of mm4 which is not a unit of area.
Of course, if you seem to be working in MKS units, we do need to convert from mm2 to m2
Thread Closed
Thread Tools
Similar Threads for: Material Thickness
Thread Forum Replies
Thickness of Quantum Well ?? Quantum Physics 1
thickness of insulation material General Engineering 1
Is it possible a metal to the thickness of... General Physics 3
Material Science, Material Selection Question Engineering, Comp Sci, & Technology Homework 1
Refraction Index vs. Material Thickness Atomic, Solid State, Comp. Physics 8
