Many problems regarding power etc
  • Thread starter Thread starter shafeen
    Power
The discussion centers on the power requirements for a system weighing 300 kg that needs to achieve a speed of 25 km/h, with a power supply of 6 kWh. The user initially considers using a 1 hp motor, equivalent to 746 W, to meet this requirement. However, calculations reveal that the motor is insufficient, as it can only provide energy over a longer time frame, specifically about 9.7 seconds to achieve the necessary kinetic energy. The distinction between power and energy is emphasized, clarifying that the motor's power determines the time taken to reach the required energy.
  • Understanding of kinetic energy calculations
  • Familiarity with power and energy units (Watt, kilowatt, joule)
  • Basic knowledge of motor specifications (horsepower to watts conversion)
  • Ability to interpret SI unit notation correctly
  • Research "Kinetic Energy Calculations for Moving Objects"
  • Learn about "Power vs. Energy in Electrical Systems"
  • Explore "Motor Selection Criteria for Mechanical Systems"
  • Investigate "SI Units and Their Proper Usage in Engineering"
Engineers, mechanical designers, and anyone involved in power system design or motor selection for mechanical applications will benefit from this discussion.
shafeen
I am in a small project and i think i have got my self tangled in some equations...
1. I have a system and to run this system the required power is about 6kwh.(system weighs 300kgs and needs to go at 25kmph,the value is taken by calculating kinectic energy)i Plan to run this system by using a motor of 1 hp.Now i want to know two things
1.Will the 1 hp motor be enough to provide the power/energy
2. 1h.p=746w
1kw=100w
10 in² = 0.006451 m²
1w=1j/s
3. well i started off with attacking the horse power thing
1H.p=746W =746j/s=(746*60*60)=2685.6 *10^3 j/hr is the thing it would supply per hour
my requirement is 6kwh(assuming run for only one hour) =6kw=6000w=6000j/s=6000*60*60=2160*10^4
hence by this calculation the motor is not enough to power...but heck something in my mind says i am doing something wrong over here
Hello shafeen, welcome to PF.
Do you mean that the required energy is about 6kWh? Because you can use almost any motor to give an object a certain amount of kinetic energy. What the power of the motor determines is how much time it takes for the object to reach that energy. This is an important point, because your problem, as it stands right now, may not be very well-posed.
First of all, try to use standard notation so that everyone knows what you are talking about. SI unit symbols don't get pluralized with an 's', it should be just 300 kg. Also, units that are named after people typically have capital letters as symbols (even though the unit names themselves are not capitalized). So, the unit named after Joule is the joule and it has symbol 'J'. The unit named after Watt is the watt and it has symbol W. EDIT: and also, we don't use the letter 'p' to mean 'per.' That speed should really be written as 25 km/h.
Second of all, I don't agree with your computation of the kinetic energy of the system (not when it is expressed in kilowatt-hours):
http://www.google.ca/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=gdM&q=(1%2F2)+*+300+kg+*+(25+km%2Fh)^2+in+kWh&btnG=Search&meta=&aq=f&oq=
As I said above, this is a very important distinction. Power and energy are not the same thing. The power of the motor is the rate at which it supplies energy. So the only really sensible question to ask is whether it can provide the required energy in a certain time interval.
shafeen said:
2. 1h.p=746w
Right.
shafeen said:
1kw=100w
Wrong.
1 kW = 1000 W
(kilo = 103)
Can you explain what this has to do with anything?
Look, basically 746 W = 0.746 kW, meaning that the calculation goes like this (assuming the power is constant):
power = energy/time
time = energy/power
= (0.00200938786 kWh) / (0.746 kW)
= 0.00269354941 h
Which is about 9.7 seconds. Are you satisfied with that, or would prefer a more powerful motor to give the system that amount of kinetic energy faster than that?
