Understanding Newton Method for Solving Equations
The discussion revolves around the Newton method for finding roots of equations, specifically addressing its limitations and conditions for successful application. The original poster expresses confusion about the method's reliability for a given function, citing specific examples where the method yields unexpected results.
  • Participants discuss the conditions under which the Newton method may fail, such as the behavior of the derivative near the root and the presence of local extrema. Questions arise about how to determine the suitability of the method for different functions and initial guesses.
Participants are actively exploring the nuances of the Newton method, with some providing insights into the mathematical conditions necessary for its success. There is an ongoing inquiry into how to avoid pitfalls associated with the method, particularly regarding the behavior of derivatives.
There are mentions of specific initial guesses leading to divergent results, as well as the importance of analyzing the function's graph to inform the choice of starting points. The discussion highlights the need for understanding the function's characteristics before applying the method.
sara_87
I read that the Newton method for finding roots of an equation doesn't always work.
How do I know whether it works or not for a given equation?
For an example, consider:
f(x) = 1/(x2-1)+1/(x2-4) - x-1
When I try to solve this using programming, I get 2.9642 for some initial guesses but if I put the initial guess as, say, 5 I get that the root is -inf
I don't understand why.
And also for other examples I either get x=0 after 0 steps (in the Newton method) or I get x=inf.
Thank you
You need to have
[tex]\abs {f'(x)} <= 1[/tex] in the neighborhood of your guess and the solution. A local extreme between the 2 could also cause troubles.
I don't understand. What do you mean 'A local extreme between the 2 could also cause troubles' ?
Thank you
At a local extremum (maximum or minimum) the derivative is 0. Since Newton's method involves dividing by 0, it one of your iterations happens to give you that value, there's an obvious problem!
Oh so if the value gives infinity, this means that there is a problem. How do I avoid this problem.
In general, for a given function, how do I know whether I can implement the Newton Method?
As integral said, you need to know that f'(x)< 1 in some neighborhood of of the root, that f'(x) is NOT 0 in that neighborhood, and that your starting value is inside that neighborhood. Frankly, most of the time, the best thing to do is to "try and see what happens".
You would have to look at a graph of the function to see where your initial guess will take you with Newton's Method. In your case, at your initial guess x1=5, the slope of the tangent line of your function is -13/352800 and just below the x-axis. This will make x2 far to the left in negative x values and each subsequent approximation will further diverge to negative infinity.
http://en.wikipedia.org/wiki/Newton%27s_method" might help you out with some good examples of where you can run into trouble with Newton's Method.
