Register to reply
PH spectrum
by Rajini
Tags: spectrum
Share this thread:
Rajini
#1
Dec28-09, 03:08 PM
P: 602
Dear all,
i need to clarify some doubts about counting radioactive sources..
For e.g., in my case i use a proportional counter (filled with Xe-gas) for detecting radioactivity..
Now if we measure a pulse height (PH) spectrum using a detector (pulse height mode) we will get a pulse height spectrum. I read in some (i forgot the name!) book and if i understood properly that the area under the whole PH spectrum is just the activity of the source measured! (off course if the detector has 100% efficiency). no more details available in that book!.
and my question is..suppose in 57CO source the 14.4 keV is only 9.2 per 100 disintegrations...then the ratio:
area under the 14.4 keV / whole area under spectrum= say 'X'. is there some possibility to connect this 'X' with 9.2%??
or knowing the geometry, i mean the distance between the source and detector and diameter etc...is there any possibility to make use of the area under a specific curve in some formula...? to get the activity of source?
PS: PH spectrum has X-axis in volts or channels (i have the spectrum and i can select channel or volts).
Y-axis is count rate (in that book they mentioned Y-axis has inverse volts)...
I guess lots of nuclear physicist in PF hopefully some one can shield light in my problem??
thanks
Phys.Org News Partner Physics news on Phys.org
Detecting neutrinos, physicists look into the heart of the Sun
Measurement at Big Bang conditions confirms lithium problem
Researchers study gallium to design adjustable electronic components
Register to reply
Related Discussions
Relation between phase spectrum and frequency spectrum Electrical Engineering 4
Relation between spectrum in algebraic geometry and spectrum in functional analysis Linear & Abstract Algebra 0
EM spectrum General Physics 4
Absoprtion line spectrum Introductory Physics Homework 3
Level of refraction depends on what? Introductory Physics Homework 1
