| Thread Closed |
Inverse of a Piecewise Function |
Share Thread | Thread Tools |
| Dec29-09, 10:24 PM | #1 |
Find the inverse of .........{x......x =/= a1,...,an f(x) = {ai+1......x = ai, i = 1,...,n-1 .........{a1......x = an 2. Relevant equations 3. The attempt at a solution I interchanged the variables x and y, but I am very confused as to how to solve for the rest. I don't understand how to find inverses if we aren't given an explicit formula. Can someone help please? |
| Dec29-09, 11:09 PM | #2 |
| Dec29-09, 11:24 PM | #3 |
Also, could I ask for help on finding inverses for the following? f(x) = x + [x] (floor) and f(x) = x/(1-x2) for -1 < x < 1. For the first function, there is no reversible equation for the floor operator, so could I state the inverse as simply {(x+[x],x) | (x,x+[x]) [tex]\in[/tex] f}? Would it be possible to state that any x in f be a.b, where a is an integer and b is any real number? Then f(x) = a.b + a for a >= 0 and f(x) = a.b + (a-1) for a < 0. Then the inverse of f would be given by f-1(x) = 1/2 (x + 0.b) for x >= 0 and f-1(x) = 1/2 (x + 1.b - 0.(2b)) for x < 0. For the second function, I interchanged the variables and obtains: x(1-y2) = y 0 = xy2 + y - x Using the quadratic formula, I got y = (-1 +/- [tex]\sqrt{1+4x^2}[/tex])/2x, -1 < y < 1 How do I know whether to take the positive or negative? |
| Dec30-09, 06:51 AM | #4 |
You shouldn't take either one. If your calculations are correct, you are saying that this function is NOT one to one and so does NOT have an inverse.
| Dec30-09, 09:15 AM | #5 |
The floor function is not 1-1 so it does not have an inverse, but the question is f(x) = x + floor (x), so that the function is 1-1. However, I am not sure how to cleanly express its inverse. EDIT: Never mind for the floor function. Can someone please explain the first function? |
| Dec30-09, 11:53 AM | #6 |
Try drawing the graph of f-1. You will see that its domain has gaps and the segments of the graph are translates of f(x) = x. Does that help? |
| Dec30-09, 12:13 PM | #7 |
| Dec30-09, 12:46 PM | #8 |
When you interchanged x and y and solved for y you got:
[tex] y = \frac {-1 \pm \sqrt{1+4x^2}}{2x}[/tex] One way you can tell you don't want the - choice is what happens as x approaches 0. The branch you want goes through the origin. If you look at [tex] y = \frac {-1 - \sqrt{1+4x^2}}{2x}[/tex] as [itex]x\rightarrow 0[/itex] you get a -2/0 form which indicates a vertical asymptote. On the other hand if you let [itex]x\rightarrow 0[/itex] in [tex] y = \frac {-1 + \sqrt{1+4x^2}}{2x}[/tex] you get 0 as you can see if you rationalize the numerator and take the limit. Another thing that is a bit more work is to observe that with the + choice you get [itex]-1\le y \le 1[/itex], which also tells you you have the right branch. |
| Dec30-09, 12:57 PM | #9 |
I see now. Thank you so much for your help!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Inverse of a Piecewise Function
| Diffrentiating Piecewise Function | Calculus & Beyond Homework | 2 | ||
| Finding constants in a piecewise function that allow the function to be differentiabl | Calculus & Beyond Homework | 5 | ||
| We need help on piecewise function.... | General Math | 11 | ||
| Piecewise function | Calculus | 1 | ||
| piecewise function | General Math | 1 | ||
