What is the last digit of (1997)^(1997) - (1994)^(1994)?
  • Thread starter Thread starter maverick280857
The problem involves finding the last digit of the expression (1997)^(1997) - (1994)^(1994). The discussion centers around methods to determine the last digit of large exponentiations, specifically focusing on modular arithmetic and patterns in the last digits of powers.
  • Participants explore various methods to find the last digit, including examining the last digits of bases, using modular arithmetic, and identifying patterns in powers. Some participants question the feasibility of direct computation and seek alternative methods.
The discussion is active with multiple approaches being shared. Participants have provided insights into different methods, and there is a recognition of the value in exploring various strategies. No explicit consensus has been reached, but several productive lines of reasoning have been presented.
Participants note the complexity of directly calculating large powers and the focus on the last digit, which allows for simplifications using modular arithmetic. There is an emphasis on understanding the periodic nature of last digits in powers.
maverick280857
The problem:
Find the last digit of
[tex] (1997)^{1997} - (1994)^{1994}[/tex]
The Answer: 1 (one)
Will post a solution soon...I would like to know if there is a different way to do it.
Cheers
Vivek
Solution 1: Find the last digit of [tex]m^{n}[/tex]
Divide the exponent n by 4. Let n = 4p + q. Let the last digit of m be t. Then the last digit of [tex]m^{n}[/tex] is simply the last digit of [tex]t^{p}[/tex].
Do this twice to get 7 and 6 for [tex](1997)^{1997}[/tex] and [tex](1994)^{1994}[/tex] respectively. Subtract to get 1.
Solution 2: Find the last digit of [tex]m^{n}[/tex]
Let a denote the last digit of m. Enumerate the last digits of [tex]a, a^{2}, a^{3}...[/tex] and denote this series by [tex]\lambda[/tex]. The series clearly repeats after T terms where T is the period of the sequence. Note that
Let r be the remainder when n is divided by T. The remainder has the values (1, 2, 3, ..., (T-1), 0) [note that zero has been placed after the (T-1)th term so that [tex]\lambda_{T} = 0[/tex]]. The answer then is the r-th term of the [tex]\lambda[/tex] sequence, that is [tex]\lambda_{r}[/tex].
What I want to know is: is there any other way to do this apart from the two ways mentioned above?
Cheers
Vivek
4 to an even power will always have a last digit of 6.
if 7 is raised to a power of some number n where (n-1)%4=0 then the resulting last digit will be a 7.
1994 is even thus 6
(1997-1)%4=0 thus 7
7-6=1
basically the last digit will follow some pattern in this case, the powers of 4 flip flop between 4 and 6 while the powers of 7 rotate through 7,9,3,1.
Yes, instead of evolving general rules I found it quite enlightening to figure out the last digit without using the methods outlined in my second post :-D
Cheers
Vivek
Why didn't you just multiply out by hand and subtract?:confused:
Arildno, do you really think that would be possible?! Thats [tex]1997^{1997}[/tex] and [tex]1994^{1994}[/tex] we're talking about! It would take me days (if at all I managed to do it).
Cheers
Vivek
Oh, I hadn't thought of that! (Or, possibly I had..:wink:)
Wer're only interested in the last digit of [itex]1997^{1997}[/itex] and [itex]1994^{1994}[/itex], so consider these numbers modulo 10.
[tex]1997^{1997} \equiv 7^{1997} \mod 10[/tex]
[tex]1994^{1994} \equiv 4^{1994} \mod 10[/tex]
Since [itex]\left(\mathbb{Z}\slash_{10}\mathbb{Z}\right)^*[/itex] forms a group under multiplication, raising an element of the group to the power equal to the order of the group equals 1. The order of [itex]\left(\mathbb{Z}\slash_{10}\mathbb{Z}\right)^*[/itex]
is [itex]\varphi(10)=\varphi(2)\varphi(5)=4[/itex].
Since
[tex]1997 \equiv 1 \mod 4[/tex] and
[tex]1994 \equiv 2 \mod 4[/tex], we have
[tex]7^{1997} \equiv 7^1 \mod 10[/tex] and
[tex]4^{1994} \equiv 4^2 \mod 10[/tex]
[tex]7-4^2 \equiv 1 \mod 10[/tex]
So the last digit is 1.
This is the method I learned from my algebra class, but it's principally the same as Fausts' solution.
Yes it is, except that it is more formal.
Thanks and cheers,
Vivek
It's not that hard to exponentiate out, especially if you realize that you only care about the last digit:
[tex]1994=1024+512+256+128+8+2[/tex]
and
[tex]1997=1024+512+256+128+8+4+1[/tex]
Recognizing that we can throw away everything except the last digit:
[tex]7^1 \equiv 7[/tex]
square to get
[tex]7^2 \equiv 9[/tex]
square to get
[tex]7^4 \equiv 1[/tex]
So [tex]7^{4n} \equiv 1[/tex]
so we have
[tex]1997^{1997} \equiv[/tex]
[tex]7 ^{1024+512+256+128+8+4+1} \equiv[/tex]
[tex]7^{1024} \times 7^{512} \times 7^{256} \times 7^{128} \times 7^{8} \times 7^4 \times 7^1\equiv[/tex]
[tex]1 \times 1 \times 1 \times 1 \times 1 \times 1 \times 7 \equiv[/tex]
[tex]7[/tex]
Similarly:
[tex]4^1 \equiv 4[/tex]
[tex]4^2 \equiv 6[/tex]
[tex]4^4 \equiv 6[/tex]
So [tex]4^{2^n} \equiv 6[/tex] for [tex]n>1[/tex]
now
[tex]1994^{1994} \equiv[/tex]
[tex]4^{1024+512+256+128+8+2} \equiv[/tex]
[tex]4^{1024} \times 4^{512} \times 4^{256} \times 4^{128} \times 4^{8} \times 4^2 \equiv[/tex]
[tex]6 \times 6 \times 6 \times 6 \times 6 \times 6 \equiv[/tex]
[tex]6^6 \equiv[/tex]
[tex]6[/tex]
Even without that [tex]x^y(mod z)[/tex] is [tex]O(\log_2(y) {\log_2(z)}^2)[/tex] or so. Certainly within paper and pencil calculation range for the numbers you gave
Thanks faust9, Galileo, arildno and NateTG
I learned a lot from the approaches you folks suggested...thanks.
Cheers
Vivek
  • · Replies 19 ·
  • · Replies 104 ·
13K
  • · Replies 105 ·
12K
