Method of Images in Electrostatics
The discussion revolves around the method of images in electrostatics, specifically involving a point charge and a spherical conductor. The original poster is tasked with explaining the need for an additional image charge when the conductor is set to zero net charge, as well as determining the potential of the conductor.
  • The original poster attempts to reason why an additional image charge is necessary, suggesting that the total charge of the image charges should equal zero. They propose placing the image charge to create a dipole effect but express uncertainty about the justification.
  • Some participants question the placement of the second image charge and suggest using Gauss's law to justify the need for equal total charge in different configurations.
  • Others propose focusing on the electric field's behavior at the surface of the conductor to determine the correct position for the image charge.
  • One participant mentions the challenge of calculating the electric field due to multiple charges and seeks advice on simplifying the mathematics involved.
The discussion is active, with participants exploring various interpretations of the problem and offering guidance on how to approach the placement of the image charge. There is no explicit consensus, but several productive lines of reasoning are being examined.
Participants are navigating the complexities of the problem, including the implications of setting the conductor's net charge to zero and the mathematical challenges associated with calculating electric fields from multiple charges.
timhunderwood
A point charge q is held a distance d > a below the centre of a large spherical conductor of radius a. Show that, if the spherical conductor is earthed, the potential outside the sphere may be found by placing an image charge at a distance c=a2/d from the centre of the sphere, and determine the charge stored on the spherical conductor.
(I CAN DO THIS PART OF THE QUESTION FINE)
Instead of being earthed, the net charge on the spherical conductor is now set to zero. Explain why, in order to represent the electric field outside the conductor an additional image charge must now be included inside the sphere, and determine the potential of the conductor.
I found the image charge to have a charge -aq/d
I can do the first part of the question fine. But I'm getting confused when we set the conductor to zero charge.
My reasoning for why we need an additional image charge is that ( I Think) the overall charge of all the image charges inside the conductor should now also be zero. Hence, we would need an image charge of +aq/d inside the sphere...
My intuition was to put it at a distance a^2/d in the opposite direction to the other image charge so it makes a dipole with it centred at the origin of the sphere... But I don't really no if this is right or if its justified.
I don't know how I can then calculate the potential easily without doing a lot of trig and maths?
Thanks very much
hmmm... I had a nice long writeup and then I realized that I was completely misunderstanding the problem :smile:
Anyway, you had a good idea, thinking about the total of all the image charges. To justify it (I don't know if you did this), I would use Gauss's law with a very large Gaussian sphere. Since the two configurations (point charge with uncharged conductor vs. point charge with image charges) need to generate the same electric field, they had better have the same total charge, q.
To find exactly where you need to place the other image charge, I would try using the fact that the electric field at the surface of the conductor needs to be perpendicular to the conductor. (I haven't done the problem myself, so I can't guarantee this will work, but I suspect it'll get you somewhere) Once you figure out where that other charge goes, you can use the fact that the potential is constant throughout a conductor: in order to find the potential of the conductor, you only need to compute it at one point. And I'm sure you know how to compute the potential produced by a system of point charges at one point...
I'm having trouble calculating the position of the second image charge. I tried putting it at an arbitrary distance from the centre on line with the other image particle.
Then I try to calculate the field due to all three particles at the radius of the conductor. But I think I'm making a mistake as I get a quartic equation which I had to get my computer to solve.
Whats the best way to do this bit? Is there a trick to simplify the mathematics of working out the field on radius at an arbitrary angle?
Thanks
Don't calculate it at an arbitrary angle - calculate it at whatever angle is most convenient, and then check it at an arbitrary angle.
But here's my line of thought: if you know that there is exactly one additional image charge, there's really only one place you can put it that will make the net electric field perpendicular to the surface of the sphere at all points.
ah got it now
thanks very much
timhunderwood said:
ah got it now
thanks very much
2005 Paper 1 Question B7? :D
