How does a chip store so much information?
  • Context: Undergrad
  • Thread starter Thread starter Marciano
A memory chip stores vast amounts of information by utilizing capacitors and transistors. Each bit of memory consists of a capacitor that holds an electrical charge and a transistor that detects this charge. Writing a 'one' involves filling the capacitor with charge, while a 'zero' is represented by an empty capacitor. The miniaturization of these components to just a few hundred atoms in width allows for a high density of bits on a single chip.
  • Understanding of semiconductor physics
  • Familiarity with digital electronics concepts
  • Knowledge of capacitors and transistors
  • Basic principles of binary data representation
  • Research semiconductor fabrication techniques
  • Explore the principles of charge storage in capacitors
  • Learn about transistor operation and types
  • Investigate advancements in memory chip technology, such as 3D NAND
Electronics engineers, computer scientists, and anyone interested in the design and functionality of memory chips.
Marciano
Why a chip that can store so much information? I´m not seeking a traditional technique answer.
M/S
You mean a memory chip?
In simple terms each 'bit' of memory contains a capacitor which can store a small amount of electricity, and a transistor which can measure electricity.
To write a 'one' you fil the capacitor with electrical charge, to write a zero you empty the capacitor.
To read the memory the transistor measures if there is electrical charge on the capacitor or not.
You can fit a lot of them on a chip because you can make both the capacitor and transistor very small - only a few 100 atoms wide.
  • · Replies 40 ·
  • · Replies 18 ·
  • · Replies 19 ·
